Speed Density Iat or
Old Sep 7, 2017 | 09:15 PM
ant_turbo's Avatar
which is better to run Iat sensor or just use the fuel temp.. for speed density ,, and will one or the other run better then each other ?? and which one is easier to tune
Thanks
Old Sep 7, 2017 | 09:44 PM
tscompusa's Avatar
Both work the same for the most part. Majority of customers use fuel temp because its free.
Old Sep 7, 2017 | 10:14 PM
ant_turbo's Avatar
Thanks.. the reason I ask is. Currently I am tuned on Speed density omni 4bar viva fuel temp. And on cold starts the cars wants to die AF is all over the place I have to keep it idled and warm it up ..if I don't let it warm up before I drive it .it will give me a map sensor error.. So I ended up buying spoiling up setup with the MAF connector to map sensor to iat sensor hoping .maybe it will be better for tuning and and much more smoother idle and running car
Old Sep 8, 2017 | 03:22 PM
tscompusa's Avatar
Tuning fixes the poor start and dying when cold or being able to drive the car cold. Most tuners have a hard time with speed density on stock ecu.
That cable wont fix that issue without a retune.
Old Sep 8, 2017 | 04:20 PM
LetsGetThisDone's Avatar
As Tom said, you're simply experiencing a poorly done speed density tune.
Old Sep 8, 2017 | 04:43 PM
RightSaid fred's Avatar
It's only a speed density tune if it's got an AIT sensor in the manifold.
Without it, it's a speed pressure tune.
Old Sep 8, 2017 | 04:44 PM
ant_turbo's Avatar
Thanks guys...
Old Sep 8, 2017 | 07:32 PM
4b11slayer's Avatar
P.s most of the tephra sd roms are already programmed for fuel temp
Old Sep 9, 2017 | 06:03 AM
Fuel temp isn't manifold temp.
Manifold temp is manifold temp with an IAT sensor.....otherwise another fail.
Turbo01s2k
Sep 25, 2011 10:03 AM
Evoryder
Aug 2, 2011 10:05 PM
partyboy1122
May 16, 2011 06:18 PM
recompile
34
Jun 4, 2008 05:43 AM
