car is rich at idle/cruise...need logs looked at...help...
Old Nov 14, 2017, 12:41 PM
  #31
nor11384's Avatar
Here is what he was talking about...
Attached Thumbnails car is rich at idle/cruise...need logs looked at...help...-5fc7c131-059a-4033-815b-a23c6b556b59.jpeg
Old Nov 14, 2017, 01:25 PM
  #32
LetsGetThisDone's Avatar
Received 1,547 Likes on 1,326 Posts
That's one way to force open loop.
The other way is to set those open loop tables to be in open loop at any load above 0 or 5, or some other low number. The car idles at 30-40 load, and load only goes up from there. Your car was in full time open loop.
Old Nov 14, 2017, 03:04 PM
  #33
nor11384's Avatar
Fack...well car idles at a steady 14.7 - 15.2 ish now and cruise is good...I know maybe it’s not the correct way but is it ok like this? at least for now? What can happen?
Old Nov 14, 2017, 03:57 PM
  #34
He probably adjusted those tables so that the car idles and cruises in closed loop now.
Old Nov 14, 2017, 04:21 PM
  #35
nor11384's Avatar
Could it be that with the o2 sensor not working the car went into open loop itself and after fuel trims started reading it went to closed loop?
Old Nov 14, 2017, 04:51 PM
  #36
seeaich's Avatar
By the sounds off it he just threw the 02 in and it was fine. which would make sense...
OP those table i posted are the still at 5 across the board?
Old Nov 14, 2017, 04:55 PM
  #37
nor11384's Avatar
I have to check and see but I don’t think he changed it...
Old Nov 14, 2017, 04:57 PM
  #38
seeaich's Avatar
No.
Having a value of 5 across all tables was putting your car into open loop. loads under that value would be in closed loop, values above 5 would be in open loop. Considering your car Idles at ~30/40 load its always in open loop.
thats my cumbersome understanding anyways. Im sure Razorlab or someone can give a better more in depth explanation.
Can you share any logs with us from when the o2 has been replaced?
Old Nov 14, 2017, 05:26 PM
  #39
RazorLab's Avatar
Received 1,044 Likes on 762 Posts
If it was set to run in open loop (which it was if you where running the ROM you shared) then the ecu didn't care about the front 02 sensor whatsoever. It could have been melted, dragging under the car, made out of ice cream, whatever.
Old Nov 14, 2017, 07:18 PM
  #40
nor11384's Avatar
Then how come changing the o2 sensor made the car run like it used to? I was looking at him on the lap top the whole time and I didn’t see him change those tables. I’ll see if I can get a new log and pull the rom. This cable I have is messed up so I have to wiggle and mess with it until it reads and sometimes means me sitting there half an hour just to get one log but I want you guys to see it because I’m curious to figure out what changed.
Old Nov 15, 2017, 12:24 PM
  #41
nor11384's Avatar
guys i been trying to pull the rom and a log for you guys but this able finally kicked the bucket...i used to be able to wiggle it until it worked but it seems like thats it...i have to save and buy a new one or borrow my friends 2.0 and buy that little side cable...
Old Nov 17, 2017, 10:42 AM
  #42
It started working because he changed the ROM at the same time you changed the O2 sensor.
Also, if the front O2 was dead causing you to not get O2 feedback, you would have had a code.
Old Nov 17, 2017, 11:07 AM
  #43
nor11384's Avatar
There’s some weird **** going on there because at first he was looking at the log and fuel trims were at 0. I started taking the spark plug cable cover off the valve cover and he said the trims started reading and couple seconds later they stopped. I started wiggling **** to see if it was a bad connection but nothing so we changed the o2 sensor and at first fuel trims were at 0 but then they started reading and been fine ever since. He said it was just the o2 sensor warming up. Idk. I never got a cel on the car.
Old Nov 17, 2017, 11:45 AM
  #44
What you're describing should have caused a code. Very odd if it didn't.
And, if your open loop load tables are what you posted, the front O2 shouldn't be on.
Old Nov 17, 2017, 01:00 PM
  #45
nor11384's Avatar
Idk man when it comes to tuning not too familiar. I’ll try to get a cable.
turbotaloon95
Oct 20, 2013 02:58 PM
triguy
Aug 4, 2013 08:39 PM
mrb00st
Feb 21, 2013 08:33 AM
beasters
Jan 13, 2013 03:25 PM
SEEnoEVO
May 21, 2009 12:12 PM
Quick Reply: car is rich at idle/cruise...need logs looked at...help...
