FIC 1200: Should I be concerned with this data match?
Old Mar 19, 2018 | 04:33 PM
Siege's Avatar
Looks like they're alright. Appreciate the reassurance guys!
Old Mar 30, 2018 | 02:36 PM
Siege's Avatar
See above ^^
Old Mar 30, 2018 | 03:44 PM
2006EvoIXer's Avatar
Interesting how one of the highest flowing injector at 43.5 psi (1217cc) flowed the least at 3 bar (1419cc). Am I reading this right?
Old Mar 30, 2018 | 05:15 PM
Siege's Avatar
I believe the offset is how long it takes to go from closed to full open so the one that's lower is the fastest injector. If I use these I was going to put that one in #2 since that appears to be the leanest cylinder from my research.
Old Mar 30, 2018 | 05:42 PM
Oh right, it's in microseconds. I didn't pay attention and thought that was cc. That is the smart thing to do and match that up.
But before doing that, verify with FIC that this will help to balance your mixtures.
Old Mar 31, 2018 | 02:00 PM
foxbat's Avatar
Are those the HighZ part # IS126-1200H?
I just ordered a set, can you please post your scaling & latencies, 93oct ?
Old Mar 31, 2018 | 08:32 PM
RightSaid fred's Avatar
Cylinder 4 always runs the leanest.
The offset or deadtime or whatever else you want to call it, it's an adder so it's the actual time which needs adding to the calculated injector pulse width to give the actual pulse width in order to get the correct AFR.
The time is only valid for fuel at 3 bar base pressure.
So in the case of fitting a pump that's too big and idling with 42 PSI on the gauge (9 psi more than 3 bar), the offset is greater.
Those numbers are also voltage dependent so it should state the voltage at which they're tested.
Old Apr 1, 2018 | 04:52 AM
Siege's Avatar
I still need to install and fine tune them but I'm starting with these:
Scaling: 1008
4.69 | 4.08
7.03 | 3.072
9.38 | 2.064
11.72 | 1.464
14.06 | 1.128
16.41 | .936
18.68 | .72
Latencies should be really close with initial scaling on the rich side.
I was basing my leanest cylinder comment on this thread: https://www.evolutionm.net/forums/ec...uestion-2.html
Originally Posted by DTM
The order in which we concluded was the leanest to the richest:
So your post is extremely accurate.
Cylinder #4 makes sense being the closest to the throttle body but the knock sensor being placed behind #2 supports that one being lean also.
Thanks for the good discussion guys.
Old Apr 1, 2018 | 06:33 AM
2winscroll's Avatar
You guys are splitting hairs here. We are talking microseconds, .000025 of a second delay difference between injectors awsome. even at idle isn’t gonna change afr more than a point or two. I’m sure the stock injectors aren’t even close to that good.
Old Apr 1, 2018 | 12:26 PM
Don't forget about the EGR at Intake runner #4.
Tsurugi-san
Jul 11, 2006 11:19 PM
civic/v8eater
Apr 10, 2006 10:56 PM
FinsNCanes
Sep 24, 2005 12:21 PM
steveevo8
14
Jul 6, 2004 10:18 AM
