Detecting MBT with Virtual Dyno
Old Jul 6, 2018 | 02:13 AM
foxbat's Avatar
I'm about to tune an Evo 8 using E85, short of an actual dyno, I can't think of any other method to detect MBT other than Virtual Dyno. I've read a couple of old posts regarding using VD to look for MBT, different people offer different approaches. Some say that speed should be included in the logged parameters, others say to log two parameters only, TBS & RPM-2byte), since that would offer a better logging resolution. The other issue is VD smoothing, someone suggested to use the max smoothing setting at 20 for the best resolution in detecting increases/decreases in power.
I'd appreciate your feedback
Old Jul 7, 2018 | 12:32 AM
Evo9_Dubai's Avatar
An Evo 8 running E85, using VD.... in the UAE
Old Jul 7, 2018 | 07:09 AM
foxbat's Avatar
And your point is .....?
Old Jul 8, 2018 | 09:19 PM
Ayoustin's Avatar
You will absolutely not find MBT on E85 without a proper dyno. VD is way too inconsistent for something like that.
Old Jul 8, 2018 | 11:53 PM
Evo9_Dubai's Avatar
oops.. corrected my initial reply.. Not too many evos running e85 in the uae.
Eszterle
Jan 6, 2011 03:51 AM
4g94T
Lancer Engine Management / Tuning Forums
11
Jun 20, 2009 06:04 PM
Hooptie157
Feb 26, 2004 01:35 PM
