CAR FLAGGED FOR CA State REF "PLEASE HELP"
Old Aug 23, 2020 | 03:49 PM
  #31
2006EvoIXer's Avatar
Originally Posted by Chowgp
Sorry guys, I have been busy this weekend and wasn't able to respond in this thread. Thank you everyone for all the information and suggestions.
With the stock tune flashed on the ECU, would a tuner still be able to force pass certain monitors that would other wise fail? If so, would a REF know that this was tampered with? I can't imagine a REF physically checking if the EGR or PVC was working etc.
In Theory would I be able to slap on all the EGR, PVC, MAF etc and make it look like they are there and working but they aren't actually working? Have the tuner force all necessary monitor to pass. Would this fool the REF? Does force passing certain monitors cause the Cal ID / CVN to change?
After pass REF and putting all my aftermarket parts back on the car and in 2 years when I need to smog the car again. Do I simply just flash the tune back to stock and run the smog check? That way the Cal ID / CVN is matching stock and won't get flagged in the future.
oem tune needs to go back. That means all stock parts too since many aftermarket parts could cause a check engine light (rear O2, stock EGR and smog devices, stock 1 bar MAP, stock injectors, etc). You can try to cheat with aftermarket cams to seen if they check live readings (GL if you try).
Old Aug 23, 2020 | 06:42 PM
  #32
kaj's Avatar
kaj
To reiterate: all smog parts have to be on the car and functioning. The ECU can't have ANY tuning done to it. It has to be the 100% stock ROM. All as from factory. No changes or variances for anything related to smog unless it has a CARB number.
Old Aug 24, 2020 | 12:08 AM
  #33
Pal215's Avatar
Exactly. Unless you are a smog referee in CA, then the world is your oyster.
Old Aug 24, 2020 | 12:33 AM
  #34
kaj's Avatar
kaj
At one point my friends and I considered opening our own smog shop,
Then we realized there is probably some type of "conflict of interest" clause. My car would blow crazy clean, but noooo. Not good enough. LOL
Old Aug 24, 2020 | 09:19 AM
  #35
Spooled_IX's Avatar
The CVN is a checksum so yes, if just one bit is changed in the tune to bypass anything the CVN will change. I had to disable the Immobilizer which has nothing to do with emissions and this changed the CVN. The ECU has to be programmed to be completely stock and there's no way around this last time I checked unfortunately.
For ALL future smogs I would make sure your ECU has the correct values. This is what the state ref is using to flag vehicles.
Old Aug 24, 2020 | 09:22 AM
  #36
Interesting. I thought I read that the immobilizer doesn't affect the CVN. This sucks for everyone because they will have to go to stealership for retune back to stock.
Old Aug 24, 2020 | 09:25 AM
  #37
kaj's Avatar
kaj
Yep. I lost my OEM ROM when my laptop died.
Old Aug 24, 2020 | 09:27 AM
  #38
Biggiesacks's Avatar
The immobilizer code doesn't (afaik) because every one is different and you couldn't have a uniform checksum if it did (again AFAIK). The immobilizer function itself however does, so disabling it effects the checksum.
Old Aug 24, 2020 | 09:37 AM
  #39
Spooled_IX's Avatar
Yep, the 4-digit hex code doesn't change the CVN, but disabling the function by changing the (FAA bit) DOES change the CVN.
Old Aug 24, 2020 | 09:56 AM
  #40
oh wow, that screws everyone that doesn't have their immobilizer code then!
Old Aug 24, 2020 | 11:28 AM
  #41
RazorLab's Avatar
I can also state that the immobilizer doesn't change the CVN. Just use any OEM ROM and input your correct immobilizer number.
Old Aug 24, 2020 | 03:54 PM
  #42
That's the problem with tuned ecus. Tuners don't usually carry over the immobilizer code and once tuned, the code will be overwritten and lost. I had to get mine back from dealer. Any other way to get it other than dealer?
Old Aug 24, 2020 | 04:05 PM
  #43
RazorLab's Avatar
Lazy tuners then. I've always brought over the immobilizer on thousands of tunes I have done. I also have kept every single pulled ROM pre-tuning from those cars on my server.
Old Aug 24, 2020 | 04:09 PM
  #44
I wonder if setting the immobilizer code to all Zero's and unplugging the module would work.
Old Aug 24, 2020 | 04:11 PM
  #45
agreed. It only takes 1 minute to copy and paste code over. Just sad how much of a disservice they did to not bring the code over.
