Adjusting tune for exhaust manifold in ecu flash
Old May 21, 2022 | 05:40 PM
Fstyles05EB's Avatar
I’m currently on a tune making 408whp.
cams, 3071r all supporting mods. Converted to SD.
recently installed an fp manifold from stock. Fuel trims are in the +5-7 range now.
If I just adjust my injector scaling or latency to compensate for the leaning of the manifold? Will the fuel maps need to be altered also??
thanks in advance
Old May 22, 2022 | 12:03 PM
Tuxevo's Avatar
Your trims sound fine. Since your boost curve is likely to have changed with the new manifold you might want to touch up your WOT fueling and timing
Old May 23, 2022 | 02:43 PM
Ok cool. So even if the trims seem sightly lean I shouldn’t adjust latency or scaling at all?
Thank you for the response 👍
Old May 23, 2022 | 03:52 PM
Tuxevo's Avatar
It depends how **** you are. +/- 10% isn't terrible.
Old May 23, 2022 | 04:17 PM
black_out's Avatar
You wouldn't change latency or scalings anyways. Those are constants when tuned properly and should never change. The change in exhaust has changed VE which would be adjusted with the MAF/VE tables on a SD setup.
Gtizks
Dec 19, 2016 05:59 PM
stevenferris1
Apr 24, 2015 02:12 PM
novaspyder87
Aug 30, 2012 12:36 PM
BUDZ69
Jan 23, 2008 10:34 PM
evoguam
14
Apr 24, 2006 06:09 PM
