Coolant Temp Sensor Issue
Old Nov 14, 2023 | 04:35 PM
pledgekincaid's Avatar
5 Year Member
Hello all!
I have been getting base logs on my new setup and have noticed that my coolant temps sit at roughly 80*F. I even replaced the sensor and have noticed the same issue. The temp will start out at 300-something and fall to 80* give or take. Does anyone have any clue what may be causing this issue?
the dash gauge starts at C and climbs to about ~40% of the gauge but I know it is causing fueling issues.
thanks in advance!
Old Nov 14, 2023 | 04:54 PM
RobbieOh's Avatar
5 Year Member
What are you using to log?
Old Nov 14, 2023 | 04:58 PM
5 Year Member
EvoScan with a Tactrix 2.0 cable.
Old Nov 14, 2023 | 05:01 PM
RobbieOh's Avatar
5 Year Member
Are you sure your Eval/formula is correct?
Old Nov 14, 2023 | 05:10 PM
ViciousLSD's Avatar
needs a new thermostat maybe?
Old Nov 14, 2023 | 06:14 PM
5 Year Member
I considered that, but the issue is it is functionally stagnant. I’ll check in a minute once my computer is done updating so I can check the calculation for the sensor.
The thermostat is new and I know it is circulating since the radiator gets nice and toasty after a drive.
Old Nov 14, 2023 | 06:29 PM
5 Year Member
So to clarify, my coolant temp through EvoScan is reading Request 07, Function X*1.8+32, Units def F (1 byte)
So unless the request is the wrong location, the calculation is correct.
Old Nov 15, 2023 | 04:09 PM
5 Year Member
Did a bit more digging under coolant sensor monitoring and found the coolant temp scales is the correct measure. This reads and shows my car cruising around 180-190F so looks like I am good to go!
I appreciate everyone’s help!
Turbojoe89
Oct 14, 2016 06:45 AM
420a-t
Apr 18, 2012 08:21 AM
expl0d
10
Mar 13, 2007 04:21 PM
