TephraMod V7 Not compatible with AUDM Evo 8
Old Nov 16, 2025 | 06:23 AM
chris_t_evo_8's Avatar
Hi,
I've downloaded TephraMod v7 from what I believe is the source - https://www.tephra.it/files/96530706-TephraMod-V7.zip
The link says "AUDM Evo 8 - 96530706".
I've also updated immobilser codes etc... The map looks like a good starting point.
Flashing worked fine. But the car won't start. It just cranks non-stop. I originally thought it might be an immobilser issue, but it doesn't seem like it.
I cannot connect to the ecu with evo scan to datalog.
The only fix is to revert to the factory 96530006 ROM, that was already on the car.
Seems like a soft brick / software incompatiblity.
I've also discovered the region / market is TDM in the XML definition.
Would this cause issues with an AUDM evo 8?
Any help is appreciated.
Thanks
TDMs
Rpf1evolution
Jan 17, 2024 05:41 AM
vlad_rally
Apr 14, 2019 09:50 PM
Zunk87
Sep 1, 2016 03:22 PM
wcassar
Lancer Engine Management / Tuning Forums
May 24, 2012 07:12 AM
thatsMR2u
Mar 1, 2009 11:41 AM
