Tuna installed
Old Apr 24, 2004 | 10:31 PM
PDXEvo's Avatar
Thumbs up Tuna installed
Well I got my Tuna installed in my car today. It integrates really well with the UTEC Brain. I really like how you can control both boxes with one serial connection. Here is a picture of the install! I think it went really well with the AVC-R hanging below it. Took very little modification to get the box in. Just had to cut two small pieces out of the inside of the storage area. I then used a metal mounting strip to create a holder for the Tuna utlizing the screw holes that already existed in the back of the compartment.
Two questions:
When the Tuna turns on I get a number that pops up. The number is 9A5. What does that mean? Gas? The other question is on using the headsets to listen to the motor. I get musical notes that play up then down every few seconds. What the hell is that?
Old Apr 24, 2004 | 10:38 PM
MalibuJack's Avatar
9A5 is the setting.. GAS.. so your right on.. Nice install, thats how I was going to do mine, but decided to mount it elsewhere since i have my touchscreen display assembly destined to go there..
and the sound.. well, I'm not sure, where did you hook up your knock sensor?
Old Apr 24, 2004 | 10:41 PM
whiterexman's Avatar
Re: Tuna installed
Originally posted by PDXEvo
[B]
Are you serious?
Where did you mount your knock sensor? Got any pics?
Old Apr 24, 2004 | 10:46 PM
MalibuJack's Avatar
I mounted mine on the 'engine hoist' tab on the front of the head above the exhaust manifold.. seems to work even though its not the optimal place to put it.. It uses a bolt that fits the sensor perfectly except its not long enough.. but guess what, if you saved the hardware from your stock exhaust, there's a bolt with the same thread, but an inch longer that works perfectly if you reuse the tab, and put a washer between the tab and the sensor. (trust me, don't remove that tab altogether, its what they use to support the engine when they take out the transmission for service.)
Old Apr 24, 2004 | 10:47 PM
MalibuJack's Avatar
I'll post a pic tomorrow when I post the other sensor pics..
Old Apr 24, 2004 | 11:21 PM
MPZ06's Avatar
Sorry for this stupid ? question? but what the heck is a "tuna"
I'm getting my turbo XS on tuesday and tryung to learn all I can.
thanx
Old Apr 25, 2004 | 10:28 AM
PDXEvo's Avatar
Tuna is just what they call the "Tuner". Its a wideband box that connects to your UTEC brain.
I mounted my knock sensor on the engine hoist tab just like MJ did. The tone that plays seems to be generated by the box. Ill hook up my laptop to it and see if I can record it.
Old Apr 25, 2004 | 11:18 AM
MPZ06's Avatar
Ah ha!!
Thanks, I should have known it was that simple.
Old Apr 25, 2004 | 09:59 PM
mick_the_ginge's Avatar
GAS means the type of fuel it's setup to read for. It can be setup for different fuels.
I hope you did free air calibration before you installed it.
I have never heard tunes from our tuners.
Old Apr 25, 2004 | 11:09 PM
PDXEvo's Avatar
Yep free air calibration is done. Took me several attempts to get it though. The damn thing is incredibly sensitive and even the wind blowing in my garage was changing the readings. I finally closed my garage then got 270 for the reading 3 times in a row so figured that was good.
So when we tuning Mick?
Old Apr 26, 2004 | 10:02 PM
frisco-wrx-dude's Avatar
wow, two top dog tuners in the same area. (both you guys in oregan).
Old Apr 26, 2004 | 11:46 PM
PDXEvo's Avatar
Actually Mick is a top dawg tuner, Im a grasshopper
Chaz17
For Sale - Part Outs
Dec 16, 2015 12:28 AM
slc-ralliart
16
Nov 21, 2010 10:29 AM
brad4tuna
10
Jun 10, 2010 05:41 PM
oogieboogie
15
Jul 7, 2005 05:36 PM
Evoisdream
60
Jun 15, 2005 11:07 AM
