New power graph
Old Jul 7, 2004 | 09:52 PM
Wizard_of_Evo's Avatar
New power graph
this is using 100 octane and tweaking the timing in MJ's stage 1 fuel & boost map a little.
the pull felt awesome. 78 degrees, 80% humidity.
marc
Old Jul 8, 2004 | 09:51 PM
MalibuJack's Avatar
Wow.. this was almost identical to the numbers I got just prior to installing my intercooler pipes and intercooler..
Old Jul 9, 2004 | 05:46 AM
GranMassaX's Avatar
marc
when you guys talk about MJs stage 1 map, is that the one that was originally posted here or has there been an updated version posted elsewhere? I haven't been on the forums in awhile
thanks guys
Old Jul 9, 2004 | 08:22 AM
MalibuJack's Avatar
Yes, that is the same map.. That map is one of the more conservative ones that I felt was safe to post.. I have a new Fuel/Boost-only map, but its tailored more for the anomolies in my fuel system and intake tract.. All the map I posted needs right now is a bit of "Smoothing" to spread the settings around a bit and make it "smoother" and then you can add a little car specific timing and pick up quite a bit of power..
However, if your going to use that map, and play with timing, I recommend getting access to a wideband O2, and possibly EGT gauge (if you plan on experimenting with aggressive timing)
Old Jul 9, 2004 | 11:50 AM
GranMassaX's Avatar
alright, thanks!
I got The Tuner, but I just gotta get it installed. I wont really "Tune" my car until I get that installed.
