afc fix k&n typhoon prob?
Old Jul 29, 2004 | 09:10 PM
1mbrews8's Avatar
I just installed a k&n typhoon and it looks good, sounds good, but it feels like I lost a lot of horses. I've read most of the threads and talked to some flashers, but no one gives me a straight answer. can the safc (or anything)fix the lean condition/power loss, etc, would it be worth it, or should I return it? what intake is better aem, hks, stock, or the k&n drop in/ thanks
michael
Old Jul 31, 2004 | 07:10 AM
MalibuJack's Avatar
Yes.. But without a wideband setup, or Dyno tune you'll have a hard time finding where its lean and how much.. The problem with some of these intakes is they sometimes cause MAF sensor misreads or turbulence, sometimes its difficult to tune for because its characteristics change depending on conditions or engine RPM..
However, you should be able to add about +2 to +4 or more at around 3000-4800rpm and it should help you...
Just so you know, the weakness you feel is actually a "Relearning" issue, that is, the ECU needs to relearn the new settings and fuel trims, so it feels weaker at part throttle driving.. But adding a bit of fuel should help you a little.
The truth is I've heard a few horror stories about the K&N, I don't know that its actually as hard to tune around as people think, but you do need to have enough headroom in fuel injector capacity (and MAF sensor capacity) to keep from hitting fuel cut.. But give that a try, You will have to add approx +2 to +3 at your Lo-Th settings and as high as +3 to +8 on the Hi-Th settings..
Again, the best way to do this is to do it on a dyno or with a wideband, however its a good starting point, and worth a shot before you give up on it.. For some it just is too big a PITA to deal with.
Old Jul 31, 2004 | 06:27 PM
GBEvo's Avatar
I had the same problem with my car feeling like it lost power after installing my Typhoon intake. I installed the SAFCII with and put in the safe recommended settings going up to a -14% and I felt a definite noticeable increase in power. I'm still playing around with adding some fuel around 3500-4000 rpm but I'm mainly trying to figure out how to solve the stalling problem after installing the intake. Adding fuel makes it a little better but the car runs rich at take off and emits black smoke out the tailpipe. The SAFCII will definitely help your power loss problem though!
Old Aug 16, 2004 | 11:36 AM
500whp.com's Avatar
michael
K&N will run really really rich! HKS RS will fix the problem a lot!
trpotts
Cobb AccessPORT
13
Mar 11, 2013 01:50 AM
13EVOX
Jan 3, 2013 06:08 AM
Demon_ni2
Lancer Engine Tech
Jun 22, 2006 10:52 AM
ZeroFrost
Jul 25, 2004 08:50 PM
EvoBoy03
105
Jan 30, 2004 02:40 PM
