Harness - which side is ecu side?
Old Aug 5, 2004 | 02:21 PM
Technoz's Avatar
is it the male or female side of the fields harness that is the ecu side. I'm getting some weird readings (i.e. throttle at ~25% at idle and nothing from the rpm) and wanted to make sure I don't have everything wired backwards or upside down or something. Thanks guys
Old Aug 5, 2004 | 02:25 PM
bahamut's Avatar
Wired it wrong. At idle, you should at most bounce from 0-2% throttle to whatever standstill idle from 800-1200 rpm.
Old Aug 8, 2004 | 06:07 AM
Whooopasss's Avatar
Registered User
male ecu side.. read thread 'right ecu pin out" https://www.evolutionm.net/forums/sh...ad.php?t=87567
Old Aug 11, 2004 | 03:07 PM
Technoz's Avatar
thanks, got it hooked up and it kicks ***
jameswwt
Feb 15, 2016 05:59 AM
slippi84
Jul 28, 2015 06:10 AM
NightHawk
May 16, 2013 12:54 PM
projekt_shocker
Jan 14, 2008 11:16 AM
