Stage 1 Map help
I have been checking my logs and the mod maf and the stock maf in stock mode are different. I bet it is just different sample times. I am not sure though. I guess it is not that big of deal.
Ben
Ben
yes.. the input and output of the UTEC is a bit out of phase.. so they both read slightly different but average about the same when no offset is used.. its a few Milliseconds behind..
It does affect the car slightly (I have verified it runs slightly leaner with the UTEC installed as opposed to the stock ECU only) but its not a huge difference (not enough to affect things negatively)
Originally Posted by MalibuJack
I didn't read if you did or didnt have one, but do you have some sort of aftermarket intake?
I am running the stock air box. I did another pull tonight in third gear, but the timing looks a little better. Similar conditions, environmentally, but I was limited with a car in front of. So that's why the log cuts out around 6k.
Tomorrow, when I get the chance, I will pull the negative on the battery and reset the ECU. Then I will log some pulls again. We'll see what happens...
From tonight.
Code:
2487,+27.4, 314, 53, 00, 00, +21.2, 10.0,ECU. , +0.0,ECU. , 299 2529,+27.2, 294, 99, 10, 00, +18.4, 11.0,ECU. , +0.0,ECU. , 339 2583,+27.2, 291,100, 10, 00, +18.5, 11.0,ECU. , +0.0,ECU. , 346 2606,+27.2, 382,100, 10, 00, +18.5, 12.0,ECU. , +0.0,ECU. , 351 2712,+27.2, 326,100, 10, 00, +18.6, 13.0,ECU. , +0.0,ECU. , 397 2745,+27.0, 388,100, 10, 00, +17.4, 14.0,ECU. , +0.0,ECU. , 381 2834,+27.0, 431,100, 10, 00, +16.3, 16.0,ECU. , +0.0,ECU. , 495 2908,+27.0, 432,100, 10, 00, +14.5, 17.0,ECU. , +0.0,ECU. , 518 2944,+27.0, 612,100, 10, 00, +13.5, 18.0,ECU. , +0.0,ECU. , 406 3030,+27.2, 636,100, 10, 00, +11.4, 20.0,ECU. , +0.0,ECU. , 498 3118,+27.2, 465,100, 10, 00, +9.4, 24.0,ECU. , +0.0,ECU. , 495 3217,+27.0, 697,100, 10, 00, +7.5, 28.0,ECU. , +0.0,ECU. , 699 3326,+27.2, 635,100, 10, 00, +6.6, 32.0,ECU. , +0.0,ECU. , 707 3457,+27.2, 925,100, 10, 00, +6.0, 36.0,ECU. , +0.0,ECU. , 773 3534,+27.2, 710,100, 10, 00, +4.9, 40.0,ECU. , +0.0,ECU. ,1039 3671,+27.2, 980,100, 20, 00, +5.0, 42.0,ECU. , +0.0,ECU. ,1113 3822,+27.2,1048,100, 30, 00, +6.4, 45.0,ECU. , +0.0,ECU. ,1108 3926,+27.0, 730,100, 30, 00, +5.2, 48.0,ECU. , +0.0,ECU. ,1106 4079,+27.0,1046,100, 30, 00, +5.4, 50.0,ECU. , +0.0,ECU. ,1275 4214,+27.0,1149,100, 30, 00, +5.4, 50.0,ECU. , +0.0,ECU. ,1157 4385,+27.0, 818,100, 30, 00, +6.8, 50.0,ECU. , +0.0,ECU. , 850 4438,+27.2,1219,100, 40, 00, +6.8, 52.0,ECU. , +0.0,ECU. ,1237 4572,+27.2,1152,100, 40, 00, +7.0, 54.0,ECU. , +0.0,ECU. ,1108 4714,+27.2,1138,100, 40, 00, +6.9, 57.0,ECU. , +0.0,ECU. ,1004 4844,+27.2,1234,100, 50, 00, +7.3, 58.0,ECU. , +0.0,ECU. ,1002 4990,+27.2,1246,100, 50, 00, +8.1, 59.0,ECU. , +0.0,ECU. ,1219 5065,+27.2,1302,100, 60, 00, +8.1, 61.0,ECU. , +0.0,ECU. ,1358 5241,+27.2,1149,100, 60, 00, +8.2, 63.0,ECU. , +0.0,ECU. ,1308 5324,+27.2,1424,100, 60, 00, +8.6, 64.0,ECU. , +0.0,ECU. ,1240 5437,+27.0,1305,100, 60, 00, +6.0, 67.0,ECU. , +0.0,ECU. ,1381 5583,+27.0,1362,100, 60, 00, +5.4, 70.0,ECU. , +0.0,ECU. ,1400 5640,+27.0,1278,100, 60, 00, +6.2, 72.0,ECU. , +0.0,ECU. ,1400 5767,+27.0,1392,100, 70, 00, +7.7, 73.0,ECU. , +0.0,ECU. ,1552 5847,+27.0,1445,100, 70, 00, +8.7, 73.0,ECU. , +0.0,ECU. ,1557 6027,+27.0,1445,100, 70, 00, +9.8, 75.0,ECU. , +0.0,ECU. ,1412 6105,+27.2,1355, 62, 70, 00, +10.7, 73.0,ECU. , +0.0,ECU. , 254
Code:
2332,+27.4, 266, 87, 10, 00, +18.2, 10.0,ECU. , +0.0,ECU. , 294 2420,+27.2, 258,100, 10, 00, +17.2, 11.0,ECU. , +0.0,ECU. , 326 2478,+27.2, 342,100, 10, 00, +18.3, 12.0,ECU. , +0.0,ECU. , 309 2540,+27.4, 360,100, 10, 00, +16.3, 13.0,ECU. , +0.0,ECU. , 352 2602,+27.4, 390,100, 10, 00, +16.3, 14.0,ECU. , +0.0,ECU. , 316 2668,+27.4, 417,100, 10, 00, +15.2, 15.0,ECU. , +0.0,ECU. , 408 2750,+27.4, 448,100, 10, 00, +15.3, 17.0,ECU. , +0.0,ECU. , 404 2834,+27.4, 513,100, 10, 00, +13.5, 19.0,ECU. , +0.0,ECU. , 399 2984,+27.4, 452,100, 10, 00, +10.0, 21.0,ECU. , +0.0,ECU. , 612 3063,+27.4, 486,100, 10, 00, +7.9, 25.0,ECU. , +0.0,ECU. , 582 3214,+27.4, 680,100, 10, 00, +6.1, 30.0,ECU. , +0.0,ECU. , 737 3287,+27.6, 815,100, 10, 00, +5.0, 35.0,ECU. , +0.0,ECU. , 815 3432,+27.6,1002,100, 10, 00, +5.5, 40.0,ECU. , +0.0,ECU. , 939 3568,+27.4, 868,100, 10, 00, +5.8, 42.0,ECU. , +0.0,ECU. , 720 3687,+27.4, 724,100, 10, 00, +5.7, 44.0,ECU. , +0.0,ECU. ,1182 3822,+27.2, 783,100, 20, 00, +3.8, 48.0,ECU. , +0.0,ECU. ,1138 3987,+27.2, 865,100, 20, 00, +4.0, 51.0,ECU. , +0.0,ECU. ,1052 4130,+27.2,1063,100, 20, 00, +4.0, 51.0,ECU. , +0.0,ECU. , 834 4284,+27.4,1108,100, 30, 00, +4.7, 52.0,ECU. , +0.0,ECU. , 854 4450,+27.4, 927,100, 30, 00, +4.7, 51.0,ECU. , +0.0,ECU. , 996 4591,+27.4, 980,100, 40, 00, +5.1, 55.0,ECU. , +0.0,ECU. ,1118 4688,+27.4,1168,100, 40, 00, +5.2, 58.0,ECU. , +0.0,ECU. ,1199 4796,+27.4,1336,100, 50, 00, +5.2, 61.0,ECU. , +0.0,ECU. ,1182 4952,+27.4,1101,100, 50, 00, +5.9, 61.0,ECU. , +0.0,ECU. ,1288 5065,+27.4,1404,100, 50, 00, +6.4, 62.0,ECU. , +0.0,ECU. ,1106 5184,+27.4,1385,100, 50, 00, +6.4, 64.0,ECU. , +0.0,ECU. ,1312 5376,+27.4,1377,100, 50, 00, +6.5, 67.0,ECU. , +0.0,ECU. ,1428 5500,+27.4,1428,100, 50, 00, +6.7, 71.0,ECU. , +0.0,ECU. ,1336 5574,+27.4,1557,100, 50, 00, +6.9, 73.0,ECU. , +0.0,ECU. ,1474 5688,+27.4,1329,100, 60, 00, +8.0, 75.0,ECU. , +0.0,ECU. ,1466 5837,+27.4,1479,100, 70, 00, +9.1, 76.0,ECU. , +0.0,ECU. ,1392 5995,+27.4,1633,100, 70, 00, +11.0, 77.0,ECU. , +0.0,ECU. ,1432 6038,+27.4,1562,100, 70, 00, +11.5, 79.0,ECU. , +0.0,ECU. ,1543 6184,+27.4,1592,100, 70, 00, +12.7, 80.0,ECU. , +0.0,ECU. ,1432 6277,+27.6,1428,100, 70, 00, +13.6, 81.0,ECU. , +0.0,ECU. ,1597 6422,+27.4,1492,100, 70, 00, +14.3, 82.0,ECU. , +0.0,ECU. ,1432 6548,+27.4,1362,100, 70, 00, +15.6, 81.0,ECU. , +0.0,ECU. ,1501 6613,+27.2,1547, 99, 70, 00, +16.7, 83.0,ECU. , +0.0,ECU. ,1457 6858,+27.2, 155, 11, 00, 00, +38.7, 9.0,ECU. , +0.0,ECU. , 90
It looks like the timing is pretty close to the stage 1 map.
Does the stock ECU still "learn" from knock/detonation that occurs when the UTEC takes over and TPS breaches 25%?
So, if you were running an arbitrary map 1 and it knocked... would the ECU "learn" from this knock if you revert back to map 0 (stock mode)?
You know that is a good question. But it isn't a big deal. BEcause with you timing you are adjust for absolute degress before TDC If you were adjusting the timing by a value I could see that you would see that problem. It will only affect the car under 25%tps but but you shouldn't get knock down there or you have some problems.
Ben
Ben
My understanding is all of the signals are reproduced and/or passed through to the stock ECU, therefore if knock was experienced, its likely that the ECU was aware of it regardless of what map you were in..
Odds are the ECU was extremely unhappy with something, bad gas, environmental, etc..
You are right, the timing your seeing now is real close to the TXS Stage1 map.. which is not surprising since the TXS map is very conservative and reflects what I'd see a car running 91 octane to see.. The big issue is the Fuel portion of the TXS stage1 map removes too much fuel (and is way lean) if you have modifications that raise boost higher than 19psi, or intake modifications (intercooler, pipes, intake, filter, etc..)
I don't have a boost controllers, nor do i have the ABC installed...
Is it safe to assume that 100% on the boost map equals 20psi?
Man, I really do need a boost gauge and wideband before I do anything .. otherwise I am poking around in the dark (but i knew this already)
Gotta pay to play...
you can't assume anything.. It depends on your exhaust system and other modifications.. I wouldn't change or adjust anything until you have the right instrumentation to do it.
fair enough
mikesevo8
18
Mar 1, 2009 07:46 PM
WarmPepsi
17
Sep 25, 2005 11:59 AM
TrinaBabe
15
Jun 27, 2005 12:16 PM
whiterexman
11
Oct 27, 2004 01:07 PM
