GSC Motorsports - Charleston, SC [Visit Site]
Exhaust fitment issues
Old Jul 23, 2007 | 01:55 PM
Tata's Avatar
I recently purchased the cat back system with the test pipe and I'm having rubbing issues with it. The collector after the resonator was rubbing on the drive shaft a little bit and also the resonator was rubbing on the drive shaft balancer I believe thats what it is. But its only rubbing on and off, not all the time. I was wondering If you all have had any other issues with it or what? I've adjusted the exhaust many times but its still doing it on and off.
Thank you
Old Jul 23, 2007 | 03:26 PM
Boltz.'s Avatar
FCOTM Winner
I saw a problem like this with an aps exhaust. The problem ended up being that the testpipe was on either flipped or backwards (can't remember).
try that
Old Jul 24, 2007 | 11:05 AM
GregGSC's Avatar
Try flipping the test pipe around first. if that doesnt cure it you might have to do the following.
fore use with a stock Downpipe you will need to loosen the front bolts of the downpipe on the o2 housing, and either bend up the stock handers on the Downpipe (to push the DP down slightly bout 1/2-3/4 of an inch) , or run some longer rubber exhaust hangers to push down the downpipe avalible at most autoparts stores.
Old Jul 27, 2007 | 07:02 PM
ItsMrGqToYou's Avatar
I just got your exhaust in today went to put it on same thing the exhaust hits in 3 places i did every thing you said and it just wont fit right also the gaskets you gave are not sized right i will call you tomorrow greg and see about what we can do also ill post some pics up to you can see whats wrong
meckert
Sep 9, 2016 09:53 PM
AJsGenerX
21
Mar 19, 2013 08:25 AM
bradw3488
Nov 12, 2011 09:11 PM
racr00089
11
Aug 21, 2010 10:29 PM
gvr4737
Mar 22, 2008 12:41 AM
Quick Reply: Exhaust fitment issues
