Car running like crap...
Old Nov 22, 2004 | 08:50 AM
  #46
ItsTheDriver13's Avatar
From: Danville, CA (it really is all about nor cal)
an easy way to check if it is your spark plugs and your wires versus something in the fuel delivery system s to run it untol you experience the bogging, then pull out your injectors. the ones that are nasty looking and are sitting in a pool of gas are the ones that arent firing for whatever reason. i had this problem once (non turbo and diff car, but still the same problem). i had it bogging at idle, and it would not warm up fast at all.....it ended up that i had a SMALL leak in 2 of my injector o-rings (6 cylinder). my gas milage went to about 14 mpg on a 3.0 ltr maxima that shoulda been getting about 24. i replaced the injectors and o-rings and it ran fine. never quite got my gas milage back to 100%....but the good ole right foot is to blame for that a little prolly......anyways....hope this helps a bit
Old Nov 23, 2004 | 07:09 PM
  #47
Boeturbolancer's Avatar
Dookie... sent you a pm
MC... glad you got it figured out... i would definately reset the ecu.
Teal2nnr
Feb 25, 2017 10:55 PM
guapoholic
24
Feb 24, 2017 07:47 PM
Chokkan
23
Jan 9, 2017 09:45 AM
TLeid91
Apr 4, 2016 07:43 AM
berkel
51
Apr 7, 2006 08:54 AM
