Blow'd it
i have a turbo xs manual bleed type boost controller on my wrx and it works fine. i have alot of Turbo xs components and had no problems with them and i absolutely love them. of course i also know what i was doing and wouldn't overboost my car. you can't simply throw more boost. you need to have the proper fueling AFR ignition retard and compression ratio. it sounded like the piston might have melted so you should have had an egt gauge to make sure it wasn't getting too hot and an AFR and boost gauge to make sure you don't detonate. also you need to run premium gasoline. in my opinion the Turboxs Boost controller isn't at fault i believe it was ignorance in knowing how to tune it.
Originally Posted by Hotshot940
we don't know any cases in which theyve blown from not fooling around tho.
lowering compression isn' the best idea
why do you say lowering compressions isnt a good idea?
the boost controller isn't the problem, crnesst, list all your mods please.
RRM Header
Greddy EVO. Cat-Back Exhaust
Magnacore Wires
RRM High-Flow Cat
Upgraded Fuel Rail
Greddy Type-S BOV
Nology Silverstone Spark Plugs
Turbo XS HP Boost Controller
Ralliart Ground Wire Kit
Turbo Heat Shielding Kit
the problem could lie in the plugs...just an idea tho.
mike - to my knowledge, nobody has done this yet and it isn' t gauranteed that the gains to be found during boost are worth what you will lose before you reach boost. if somebody wanted to do it id be interested in seeing the numbers tho, and more importantly the power curve.
Originally Posted by sweet_bucket22
RRM kits never blow unless someone monkeys with em. Sorry to hear about it though.
alright whatever, i don't know anything, you guys got it all down pat. all i know is that when you throw in one step HOTTER plugs on a turbo setup your barking up the wrong tree, thats fine tho. I like how people always want to sit here and name their posts **** like "my car blew up" and "my rrm kit blew up" maybe someone should name it "i did some **** that was included in the kit, but i changed it and then my car blew up." others peoples kits arn't blowing up becuase they are f'ing with stuff. as far as lower compression pistons, thats fine, i havn't seen any numbers from them but i'm sure that there are gains to be had, all i know is that everyone has different uses for their cars and mine arn't already found on the top end.
Everyone is allowed their opinion. Why freak out about it?
Originally Posted by HobieKopek
Welcome to the club.
