RPW Turbo Pricing
Originally Posted by 03RallyLancer
aq u have this? if so what all does it replace/do... would like to get another review... not that i dont trust dave, just its his product
Nonetheless, basically, anti-lift bushings change the castor angle which helps prevent the nose from lifting under hard acceleration, thus the name. Technically, rotational forces of the axle cause the suspension to extend, by changing the suspension angle it's harder for those forces to do what they want. Much like trying to push a block up a steep slope by pushing straight forward. They also serve to reduce understeer and increase cornering traction.
For a good example look at an R/C buggy. They have huge castor so that when you turn, the wheels start to lay over on their side. If you then roll the chassis you'll notice the wheels start to straighten back up but the turning radius stays the same.
One older member on the Mirage site (he is in his 60s but still a hard auto-x racer) did his and he aboslutely loved his. You will have to get your front end realigned after installing it tho, because with it installed you will have too much toe in.
EDIT:
MODS: if you want to move this to a new topic, feel free to do so. We have drifted away from RPW into Whiteline bushings and I apologize for the
Originally Posted by Alchemist
According to most WRX sites this is mostly noticeable with an upgraded suspension and is pretty amazing for how much it costs.
Air- how hard was the install? Dave was telling me 2 hours. and the WRX guys were saying the nuts are a PITA to get loose. Do you recall the part number?
Maybe we need a new thread?
http://www.rpw.com.au/Performance%20...er103turbo.htm
For those interested just finished another lovely turbo conversion on a 2.0 lancer - with a motec system pushed out with a new 370hp ball bearing turbo 270hp at the wheels on 12 psi boost stock motor, other than had gasket and rpw stage 1 turbo spec camshaft.
Enjoy the photos and as you can see the design of the kit is still one of the best out there.
Oh for those interested as well - a customer of ours with the 1.8 lancer engine, with our baby 250hp turbo on his car pushed 13.8 on normal tyres, and 13.2 with slicks down the quarter mile time.
The customer with the 2.0 / motec system hasn't run yet but somehow I think he may be doing a better time somehow.....
dam, those are super quick times. puts most of our times to shame, and thats from a 1.8l engine!
I really hope someone picks up an rpw turbo kit in the states and gives us a full rundown of the power. With all the options rpw offers (decompression gasket, cams, etc) you could have one helluva mean lancer
The decomp head gasket we use on most cars is our 1.10mm unit which easily allows 13 psi on stock internals with no problems at all. IT all comes down to good tuning - we finished another lancer recently with the greddy emanage instead - that layed down 220hp on only 10 psi boost with the 320hp garret turbo instead and throttle resposne was amazing.
why is it i hear a lot of postings saying "dont go past 9psi on stock internals", but these guys are hitting 13 psi, with a decomp gasket? I just got a turbo kit, and if i could run 13 psi on it, that would be fantastic
u have to remember that these guys are actually tuning the cars... they arent just putting on a FMU and letting it handle the boost... they all have at least a emanage and probably upgraded injectors, etc, etc.
