First Dyno Run....*help*
Old Oct 10, 2005 | 08:04 PM
HobieKopek's Avatar
Originally Posted by impetus19
Any exhaust leak will register leaner than normal AFR's, b/c of oxygen getting into the exhaust..
Yeah, def. I'm assuming he would have heard or smelled that, but that certainly is another possibility. 18.0:1 is very lean though. That's basically what is/was happening to my car under boost too oddly enough. I've yet to get mine resolved due to other issues, but hey...I still have hope.
Old Oct 10, 2005 | 11:36 PM
AznFlip's Avatar
Originally Posted by HobieKopek
Well, assuming FMU's normally do provide acceptable AFR ranges (and I can only assume they do because I don't remember anyone who runs an FMU setup mentioning WBO2 readings), they were probably right. Either the FMU, fuel pump or both are crappin' out. Is this only happening at 5psi or does the AFR gradually raise building up to it? like 15.0 at 4psi or is it normally rich then shooting up? Is there noticable knock? Are you certain the WBO2 was calibrated correctly? Tryin' to think of variables to rule out, but I'm also writing a lot of papers all week so my brain's kinda in left field....
Here is my dynosheet.
The guy said it starts to lean out once it's boosted and I'm pretty sure their o2 sensor was working properly.
Old Oct 10, 2005 | 11:42 PM
Lancerguy'03's Avatar
yeah there O2 is working correct....cause the numbers show that he is running lean. ill talk to u tommorw and hopefully get **** sorted out....with my hrs on the phone to Rock and trip to RRM....my hrs of dyno time and testing everything....i should be able to help...why am i not a guru....LOL
ALSO Intec racing is GAY AS HELL!! you should go down to AXIOM! much better there....i forgot the dudes name that works there but his is a turbo GOD! and also the owner of the shop LOVES!!!! Evos, STis and my car!
Old Oct 10, 2005 | 11:49 PM
AznFlip's Avatar
Didn't really care much, just didn't want to travel all the way to Tacoma/Lakewood for a baserun. But dyno tuning, I might . Well I'll just talk to you tomorrow.
Old Oct 11, 2005 | 12:51 AM
akasirlancerlot's Avatar
good luck
Old Oct 11, 2005 | 09:04 AM
HobieKopek's Avatar
Yeah, that's exactly what happens on my car. If I had to guess I'd say it's the fuel pump. Guess we'll find out soon enough.
Old Oct 11, 2005 | 09:48 AM
grubiaco's Avatar
lancerguy what was the problem with your setup?
Old Oct 11, 2005 | 12:26 PM
AznFlip's Avatar
He had a bad fuel pump and it was causing him to run lean. Probably that's my issue, I'll find out tonight.
Old Oct 11, 2005 | 02:38 PM
ozrally0303's Avatar
just out of curoisty why do these fuel pumps always seem to go wrong in turbo set ups i got the walbero 255 and was told its a good pump what are you guys using
Old Oct 11, 2005 | 02:42 PM
ive had 2 WALBRO fuel pumps go bad on me.....duno why....
Old Oct 11, 2005 | 02:44 PM
travelsize420's Avatar
he said he has a tre255 pump
Old Oct 11, 2005 | 02:45 PM
ya i know but other guys have had the pumps go bad to just wondering why
Old Oct 11, 2005 | 05:40 PM
no one knows....no one has really heard of this problem....
Old Oct 11, 2005 | 07:47 PM
HobieKopek's Avatar
Walbro 255. Not certain mine's the issue, but it still seems that way to me. It's fine until she starts building load. Positive boost pressure = problems.
Old Oct 11, 2005 | 08:20 PM
TURBOit's Avatar
fuel pump problems aren't that uncommon, especially walboros, they can be bad, id buy a new walboro 255 stick it in and see what happens, even though he is running a tre
