Stage 2+ vs. Evo 8 - Round 1
Originally Posted by Shingen
Carlos isn't so much a hater as he is immature. N1te is corrrect. A modifed stage 2 lancer will pull on a stock evo. Rather than acting like your five why not just add to the debate with fact to back you up?
Fox
Fox
Carlos
Originally Posted by N1te
Ever race an Srt-4? From a "ROLL!" maybe? 1/4 mile times with AWD and FWD are yes, comparisons verse eachother against the amount of time it takes for a car to get down the track but there are Supra's and Mustangs running 11 trapping at nearly 10mph faster than Evos. Why? Traction. So when you say 13's to compare to an Evo, you don't list any trap times; wonder why
Evo's run 11's, but they still have lower trap speeds than a xxxhp supra running an 11 trapping at well over what the Evo does. It's completely possible for a low 14 second turbo'd lancer to pull on a mid 13 second Evo if the Lancer's trapspeeds are higher and it's a highway racer. Drivetrain loss? You wouldn't need 300hp, you'd need around 250 which is almost exactly where RRM's kit puts you.
Make a Evo RWD and you can reverese the formula, higher trap speeds and lower ETs.
The torque on each engine makes a whole world of differences as well. You need great torque to still be fast above 3 digit MPHs, the Evo naturally makes tons of torque considering its small displacement.
Carlos
Originally Posted by RarStlzLncr
Not really I've only spent 7K - 8k and bought my Lancer for $15,700 in Nov. 2002.
EVO's were something like $30,000 then, plus I live on my own...rent, bills they add up.
Voiding high insurances quotes by claiming a lancer.. I am aware. The difference of price is to the advantage of the Evo overall because as you know the lancer still have to compare to the Evo brakes, steering, rims, tires, seats, suspension and all the good stuff that makes this car unique but at the end of the day Ii repeat that whatever floats your boat, if you can't get the Eevo now then you have to work your way around on your lancer.
Congras anyway!
Carlos
Originally Posted by cheb evo
Problem is, your drivetrain would not enable you to catch us off the line...you will be just like a stock SRT-4, which have all sorts of tractions issues off the line as everyone knows...please don't just compare power to weight ratios...remember all wheel drive traction vs. front wheel with similar power numbers and weight numbers...
<--MOVE OVER
66
Oct 7, 2011 01:10 PM
Trail Slide
Nov 10, 2008 09:03 AM
