SRT4 TD04 in Lancer?
Old Sep 19, 2006 | 07:25 AM
drucea's Avatar
Hey, I searched for this and only found it mentioned in the ralliart section. If I were to go custom turbo setup, I could basically use whatever turbo I wanted right? I have a friend with an SRT4 and he swapped his turbo out for the same one, just ported, and I was wondering if I would be able to use his stock turbo in a custom setup. It is a TD04LR I believe. Or would that just not be a good turbo to go with.
Old Sep 19, 2006 | 08:19 AM
Blacksheepdj's Avatar
It should work fine. As you kind of implied, anything will fit as long as you design for it.
FWIW, I know the WRXs also use the TD04. They're most effecient when water and oil cooled, so try to be aware of that.
Old Sep 19, 2006 | 09:05 AM
drucea's Avatar
yeah ive seen the wrx TD04 as well when searching. I couldn't find the difference though because I think the WRX is a TD04L and the SRT4 is a TD04LR. But yeah it would be custom so I figured it would fit. Thanks
Old Sep 19, 2006 | 09:13 AM
Dabaysevo's Avatar
I don't know if it will work, the R stands for reverse rotation like the evo turbo. Not only that but the SRT-4 turbo has its hotside and exhaust mani. cast as a single piece, correct me if I'm wrong, I think I read that in SCC when it first came out.
Old Sep 19, 2006 | 09:19 AM
drucea's Avatar
yeah i saw that as well which was worrying me. This is the manifold. Doesn't look like it will work
But OBX makes a manifold for that car that looks like a normal one.
So I'm confused, but my buddy has the turbo so I can look at it in person before I buy it. If not, I'll just find something else.
Old Sep 19, 2006 | 02:16 PM
HobieKopek's Avatar
Find something else. You're making things more complicated than they have to be.
Old Sep 19, 2006 | 02:22 PM
drucea's Avatar
lol yeah I've moved on
Old Sep 19, 2006 | 05:47 PM
Hit up NASIOC.com - going rate for a stock TD04 off the WRX is $100 shipped. And a lot of them come with very low mileage.
Old Oct 9, 2006 | 07:18 PM
01G_WRX_02's Avatar
I plan on using my stock turbo off my wrx. So sometime over the winter ill start the build.
Im geeting my manifold supplys from these 2 sites.
they have the head flange for a 4G93 Mitsubishi. that will work on our 4G94 right??
http://bmcrace.com/products/flanges/
http://www.acestainless.com/
Old Oct 9, 2006 | 07:26 PM
Yes. Same deal.
Old Nov 24, 2006 | 06:11 PM
4G93Turbo's Avatar
wow, I never knew the turbo exhaust housing was built in to the manifold on the srt-4.....wierd
gaabbee
30
Jan 4, 2013 08:06 PM
keen6883
Outlander Sport
Nov 3, 2012 03:50 AM
marcouxa1
29
May 13, 2012 09:27 PM
bnice01
Aug 11, 2007 04:20 PM
Ivany
Jul 6, 2002 02:47 AM
