My turbo set-up
Old Nov 10, 2007 | 06:15 PM
  #46
ambystom01's Avatar
Numbers sound good, the problem doesn't though.
Old Nov 10, 2007 | 06:17 PM
  #47
kungfugirl's Avatar
Sadly, niether doesn't 11:1 and boost.
Old Nov 10, 2007 | 06:22 PM
  #48
ambystom01's Avatar
Yep, but I guess that's why boost is so low.
Old Nov 10, 2007 | 06:27 PM
  #49
kungfugirl's Avatar
Hopefully he is ok,
Old Nov 10, 2007 | 07:00 PM
  #50
Mirage2.0's Avatar
Compression is not a problem here. I'm not building boost all the sudden. I'll check everythnig tomorow.
BTW, like I have mentioned in my previous post, DynoDynamics.
Old Nov 10, 2007 | 09:17 PM
  #51
Silens's Avatar
sounds pretty damn good, compared to my 220hp / 240trq on that same type of dyno, but running 10psi , crazy! Def making more hp per psi
Definatly check out the turbo, my friends dsm not long ago also stoped making boost for no reason, after checking it out, the turbo went bad.
Old Nov 11, 2007 | 08:00 AM
  #52
Mirage2.0's Avatar
Could it be my external wastegate?
Old Nov 11, 2007 | 08:07 AM
  #53
senate6268's Avatar
If your external wastegate is stuck open you will not build boost. Check that first.
Old Nov 11, 2007 | 09:08 AM
  #54
Mirage2.0's Avatar
If that would be the case, would I just have change the spring?
Old Nov 11, 2007 | 11:08 AM
  #55
kungfugirl's Avatar
Just check and see if ur spring is intact. I am not a fan of your wastegate, hopefully it is just a vaccum issue to the wastegate or something.
Old Nov 11, 2007 | 11:42 AM
  #56
Mirage2.0's Avatar
It's not vacuum.
Does anyone has a pic of their wastegate, how it looks inside? I'll post mine later on too.
Old Nov 11, 2007 | 12:43 PM
  #57
Mirage2.0's Avatar
Here is the wastegate pic as of now. It seems the same as before. It's not making any noice while running. I check the cold side of the turbo after dinner. Vacuum is connected.
Old Nov 11, 2007 | 01:18 PM
  #58
kungfugirl's Avatar
I don't think we can see "inside ours" is the piston slipping? Or is it firm?
Old Nov 11, 2007 | 01:29 PM
  #59
Mirage2.0's Avatar
It seems firm.
Old Nov 11, 2007 | 02:39 PM
  #60
senate6268's Avatar
Check every coupler to make sure you didn't blow one off. Is your car building proper vacuum? What is your vacuum reading at idle?
