External Wastegate
Old Jan 11, 2008 | 09:27 AM
Mirage2.0's Avatar
External Wastegate
How loud is your external waste gate? To be honest I thought it would be little louder. I drove turbo h22 and that **** sounded mean as hell (on 8psi).
Post some vids!!! I'll post mine this Saturday.
Old Jan 11, 2008 | 09:33 AM
iyi0521's Avatar
it depends on the lengh of the dump tube. Is yours tied into the exhaust?
Old Jan 11, 2008 | 09:54 AM
Mirage2.0's Avatar
If mine would go to the exhaust then I would not ask the question.
Mine is open dump tube. It's very short.
Old Jan 11, 2008 | 09:56 AM
InDub's Avatar
I think it also depends on how much boost you are trying to run on what size turbo.
Old Jan 11, 2008 | 10:11 AM
ambystom01's Avatar
^Exactly, if you're only running 6 PSI, it's not going to be very loud since less gas is being moved. Listen to the wastegate on a 20+ PSI Evo or STi, it's freakin loud as hell.
Old Jan 11, 2008 | 10:15 AM
InDub's Avatar
Big Turbo + Low Boost = Extremely Loud Wastegate lol
Old Jan 11, 2008 | 10:36 AM
Mirage2.0's Avatar
That explains it.
h22 turbo on 8 psi with t3/t4 turbo (ebay) with long dump tube = super loud (sounds like huge exhaust leak, lol)
So does the lenght of the dump tube matters???
Old Jan 11, 2008 | 10:51 AM
senate6268's Avatar
Originally Posted by Mirage2.0
That explains it.
The length won't matter. All that matters is that the turbo's ideal range for boost is higher than what the setup is boosting at. Because it's the wastegate's job to vent off the excess exhaust the dump tube will sound like a loud and annoying muffler.
Old Jan 11, 2008 | 11:30 AM
ambystom01's Avatar
Wouldn't how much boost you run be a major factor? If you think about it, the air being released at 6 PSI will move slower than the air being released at 20 PSI and will therefore be quieter.
Old Jan 11, 2008 | 01:52 PM
SLVROZ_03's Avatar
Also the quality of the WG would make a difference...some do open faster than others.
Old Jan 11, 2008 | 01:57 PM
Mirage2.0's Avatar
h22 had ebay, I have turbonetics.
Old Jan 11, 2008 | 02:05 PM
kaonashi's Avatar
that ebay junk was probably opening to soon then.
Old Jan 12, 2008 | 10:30 AM
cincy's Avatar
Take a 30psi capable turbo. If you run 6psi, you still have tons of flow that isnt needed and gets released out the dump tube. Now you run that same turbo at 28psi, you have just about all the flow going to the turbine wheel and almost none to the wastegate. So high psi = less noise, low boost = lots of noise.
Old Jan 12, 2008 | 11:57 AM
ambystom01's Avatar
OK that makes sense now, thanks cincy.
sgsoldier
Mar 19, 2012 06:35 PM
luckybull
Feb 25, 2011 04:47 PM
5LEEPERISAH23I
Apr 15, 2010 07:47 AM
bolsen
Sep 7, 2006 06:43 PM
maikonkun
Sep 14, 2004 10:09 AM
