My turbo build! 16G!!!
is it possible to just take the whole piece out and really get it welded.. i mean it's really only a crack. are you sure the fitting is proper? no holes on the line rite? its for sure the crack?
lol, it was a ***** to drill out as you can obviously tell.
I cant clean the new leak area all that good, I am just going to buy a new case and oil line from rrm.
On my 16G6 kit I had the runners lengthened by about 1.5" when the 4G94 flange was welded onto the manifold to address this exact issue.
I used a 45deg coupler and put it on first then dropped the whole thing in and it should just form around it.
I want to see if this will fit though http://www.atpturbo.com/Merchant2/me...egory_Code=RUB
So I have some money right now, when I go to the parts store to buy this, what do I tell them I need?
Oil filter housing? Oil pump case?
I dont know what its called lol
(btw for anyone who is wondering I pieced this kit together for under a grand)
It is technically both of those parts. Its all one piece. Its the oil filter housing, front case and oil pump all in one. That's why its almost a $300 part from Mitsu.
So it would be #38 from http://www.trademotion.com/partlocat...layCatalogid=0
No local parts stores have it/can get it
