My turbo build! 16G!!!
Old Apr 16, 2008 | 09:03 PM
  #31
senate6268's Avatar
Originally Posted by MK3Design
So it would be #38 from http://www.trademotion.com/partlocat...layCatalogid=0
No local parts stores have it/can get it
Yup. I wouldn't imagine any part stores carrying it. You'll have to order it from that site or straight from Mitsu.
Old Apr 18, 2008 | 05:36 PM
  #32
MK3Design's Avatar
Does anybody know the plug thread size for the oil feed? (the one right above the oil filter).
Is it one of these?
12MM X 1.0
12MM x 1.25
8MM X 1.5
10MM X 1.25
10MM X 1.5
12MM X 1.5
14MM X 1.5
Old Apr 19, 2008 | 03:35 PM
  #33
MK3Design's Avatar
Also, where the heck do I put the vac. line for my boost gauge through the firewall?
edit: I got it
Old Apr 19, 2008 | 05:22 PM
  #34
senate6268's Avatar
Is it one of these?
12MM X 1.0
12MM x 1.25
8MM X 1.5
10MM X 1.25
10MM X 1.5
12MM X 1.5
14MM X 1.5
None of those. It is 3/8" NPT.
Old Apr 19, 2008 | 07:52 PM
  #35
MK3Design's Avatar
Well thats what I had and it cracked the housing
Old Apr 19, 2008 | 08:04 PM
  #36
senate6268's Avatar
That's the size. Maybe you put too much teflon tape on the threads or didn't clean the liquid tape off the threads well enough when removing the block-off plug.
Old Apr 19, 2008 | 08:07 PM
  #37
MK3Design's Avatar
Okay, I also have -4an line so I am just going to buy this fitting then: http://cgi.ebay.com/ebaymotors/4-AN-...spagenameZWD1V
Hopefully everything will get here by next weekend!
(btw, I got my leak all jb-welded up - I might drive it tonight. I still bought the new oil pump/housing because I know it wont last probabally a month, lol)
Old Apr 19, 2008 | 08:21 PM
  #38
senate6268's Avatar
That's the exact same fitting I have on my engine. And I know there are a couple others using that same fitting also.
Old Apr 19, 2008 | 09:12 PM
  #39
MK3Design's Avatar
Thats good to hear
Items just bought:
Tight 90degree molder elbow (to clear hydraulic clutch)
2 -4AN female fittings
3/8npt to -4AN 90
12mm to -4AN banjo
'HKS style' Air Filter
So hopefully now I can get my feed line right and be able to get my intake routed like an EVO
Old Apr 25, 2008 | 07:40 AM
  #40
senate6268's Avatar
Any updates?
Old Apr 25, 2008 | 05:30 PM
  #41
MK3Design's Avatar
Got the parts yesterday, installing in 10 mins
Old Apr 25, 2008 | 06:15 PM
  #42
senate6268's Avatar
Awesome! Make us proud!
Old Apr 25, 2008 | 08:27 PM
  #43
MK3Design's Avatar
Well I didnt start on the case because the compressor to get the crank pulley is at a friends and I will get to that tomorrow.
I did however install the walbro fuel pump and took off my fuel rail.
My impreza 2.5 injectors(straight swap of WRX's but only 280cc) don't look like they will work, so I will need to find some new ones soon.
I will update tomorrow, this case is going to be a ***** and will probably take longer to do than a turbo install, lol. But hopefully by Sunday I can drive it around!
PS: I am very sick of seeing my 11,000mi car sitting in my garage undriveable!!!!!!!!!!! I will drive it soon though
Old Apr 26, 2008 | 05:39 PM
  #44
MK3Design's Avatar
I have it half way off right now, but now I need to take the timing belt and crap off, I dont really know what to do on this part. And there isnt a how to thread or tutorial anywhere
Old Apr 26, 2008 | 07:15 PM
  #45
senate6268's Avatar
This should help.
