My turbo build! 16G!!!
Old Apr 26, 2008 | 07:19 PM
  #46
MK3Design's Avatar
So if you use those 2 tools the cam or crank wont move?
Old Apr 26, 2008 | 07:26 PM
  #47
senate6268's Avatar
Focus on the area of the drawing with the "cross tip screwdriver." This is how you relieve tension off of the timing belt. You stick a screwdriver through the hole in the bracket that comes off that tensioner and tilt the screwdriver toward the front of your car. This will loosen tension off of the timing belt allowing you to remove it. You do the same thing when you need to put the timing belt back on.
Old Apr 27, 2008 | 08:59 AM
  #48
MK3Design's Avatar
Well guys my wife has basically had enough with this, lol. Ive been w/out a car for a few weeks now and my job is 15 miles away(borrowing from people sucks). We are going to return the car to stock and sell my parts to have someone put this cover on.
I am really upset now as I was so ****ing close and somthing so small turned out to be so big! Ive swapped a couple subaru's and honda's before but I couldnt even do this... lol
If anyone wants a full 16G turbo kit ready to bolt on(ive already made all the mods to it to fit, manifold, 3" downpipe, etc). I will sell it all for like $750 shipped! Turbo only has 20k on it. I will make a FS thread soon w/ full parts list.
Old Apr 27, 2008 | 09:33 AM
  #49
lilazn64's Avatar
man that sucks. talk some sense into her. Just tell her just a little longer, you're almost done
Old Apr 27, 2008 | 02:57 PM
  #50
senate6268's Avatar
There really is no reason to have replaced the entire front case just to address that tiny crack. That crack could've been aluminum welded or simply JB welded. I had a crack in my front case on the back side, JB welded it and have never seen the leak since. You need to properly clean it, scuff up the surface and follow the instructions to perfection otherwise you will not get it to stick.
Old Apr 28, 2008 | 03:25 PM
  #51
MK3Design's Avatar
The car is back to stock mode right now, but it wont turn over!!!!!!
lol, it ran fine w/all the parts on, any idea on what this could be?
Old Apr 28, 2008 | 03:29 PM
  #52
senate6268's Avatar
Check all your connections. Especially the ones on the timing belt side from when you tried replacing the front case. Make sure you didn't accidentally switch the connectors for the crankshaft position sensor and coil pack. It's an easy mistake to make when connecting the harness. Also make sure all your ground connections are clean and secure.
Is it cranking and not firing or is it not even cranking?
Old Apr 28, 2008 | 03:33 PM
  #53
tchouko's Avatar
Nice JOB bro...keep it up!!!
Old Apr 28, 2008 | 03:45 PM
  #54
MK3Design's Avatar
^lol
It is cranking
Old Apr 28, 2008 | 03:57 PM
  #55
senate6268's Avatar
Originally Posted by MK3Design
^lol
It is cranking
Ok. Next step is to check if you're getting fuel and spark.
Old Apr 28, 2008 | 04:01 PM
  #56
billylancer's Avatar
MK3Desein what mani is on your ride?
looks nice!
Old Apr 28, 2008 | 04:36 PM
  #57
MK3Design's Avatar
I checked the line coming out of my fuel pump and nothing pours out...
Old Apr 28, 2008 | 06:03 PM
  #58
MK3Design's Avatar
I got it running (pump was wired up wrong)...
Now there is a hissing coming from my IM manifold(I even clamped down all vaccum lines)
Old Apr 28, 2008 | 06:05 PM
  #59
looks nice!
never mind
i found what i wanted
nice worck on that
Old Apr 29, 2008 | 05:07 PM
  #60
MK3Design's Avatar
Soo.. my car idles reallly badly right now, all of my vac lines seem good, ive like quad-checked them, it also makes a bad hissing sound
I had a po303 but I think thats from the fuel pump being wired bad and not working(fixed now and cleared the code, its not back on)
