evo 8 full cat back on 03 lancer es?
Old Nov 15, 2008 | 11:51 PM
808tyson's Avatar
ok so im going to put a evo 8 16g turbo in my car but can i put a full cat back from a evo 8 ?to so that i dont have to have a muffler shop do my exhaust on my lancer ? will it bolt up or will it need some modification to make it work?
Old Nov 16, 2008 | 12:15 AM
ThunderOZ's Avatar
Check it out http://www.midwestevos.com/forums/sh...39&postcount=1
Old Nov 16, 2008 | 04:15 PM
doctorjon's Avatar
It depends on the manifold downpipe bolt pattern. I'm sure you can get the cat-back and have it customized at the shop.
Old Nov 16, 2008 | 04:31 PM
ThunderOZ's Avatar
If he uses an Evo turbo and O2 housing, the dowpipe fits great, it just needs to be extended a little bit.
Old Nov 16, 2008 | 06:05 PM
LNCRES2's Avatar
if i had to do it all over i would have just bought the aftermarket exhaust that fits since the exhaust pipe doesnt run the same rout the lancer exhaust does which if you look at the pics of my car in the link posted the exhaust runs below the back tire instead of above it which is fine but its very low and some driveways and speed bump pose some scraping issues and if there are more than 1 person in the car i scrap going up and down some hills but you can make it work if your ok with having it hang low
Old Nov 16, 2008 | 06:37 PM
ThunderOZ's Avatar
For those of you that can't get to the link for some reason...
Originally Posted by LNCRES2
where the evo exhaust meets the sleeve to connect with part of the lancer exhaust
and where the lancer exhaust meets the sleeve for the evo exhaust
Old Nov 17, 2008 | 09:37 AM
808tyson's Avatar
ok thanks every one just what i need it
Old Nov 17, 2008 | 12:47 PM
LNCRES2's Avatar
now i dont the the sensor on mine thats where we cut to make what of the lancer exhaust we had to use cause if you try to bolt a evo exhaust to a lancer it comes up short
Old Dec 4, 2008 | 06:55 AM
ThunderOZ's Avatar
So I found out why that happens. When I put my evo downpipe on, it is actually close to the length of the stock downpipe and the cat together...
Nitr0331
Lancer Engine Tech
Apr 1, 2017 04:20 PM
OhioEVO8
Feb 21, 2017 06:32 PM
ZanarkO
Jun 23, 2012 08:23 AM
userwave
Cobb AccessPORT
Apr 20, 2012 11:50 AM
Nomad4g63
17
Sep 9, 2009 07:53 AM
