injector question
Old Nov 19, 2008 | 07:35 PM
*02Lancer*'s Avatar
injector question
ok i read a lot of threads about fuel injectors my friend has a set of dsm 450 and i was wondering if these injectors would fit i know there is high impedance and low impedance injectors does anyone know what these injector's are and what ones we need?
Old Nov 19, 2008 | 11:42 PM
Demon_ni2's Avatar
um.. well thats gunna depends on what car your pulling them from.. 450's? im not sure what dsm has those, but an evo is 550cc, and there low impedence, were high impedence..
straight swaps.. are the 460cc (2nd gen?) rx7 injectors, and the 440cc wrx(02-03) injectors.
do a search, there was a good thread about this recently.
either go get some wrx injectors, if you want something used and cheap...(hope none of them are bad)
or go to RC and get a decent set.. and your dont need anything over about 500cc really, atleast not with the size turbo and amount of boost you will be running more then likely.
i did one for your..
Originally Posted by drucea
All these are direct swaps:
87.5 RX7 high impedence=460cc
93+ Non turbo supra=315cc
00+ celica gts=310cc
90-96 300zx TT=370cc
97+ Honda Prelude VTEC=280cc
02-03 Impreza=440cc
if it is the wrong impedence then you will need some resistors, but i dont know anything about those, im to lazy to research it.
Old Nov 20, 2008 | 09:02 AM
*02Lancer*'s Avatar
Sweet thanks! you dont know what stock ones happen to be do you?
Old Nov 20, 2008 | 10:02 PM
Demon_ni2's Avatar
240cc if i remember correctly (i might be off by +10cc)
Old Nov 20, 2008 | 10:06 PM
ThunderOZ's Avatar
The dsm 450s are low impedance, you'll need the resistor box.
Old Nov 24, 2008 | 05:02 PM
*02Lancer*'s Avatar
were do you get a resistor box at?how much are they, and how hard are they to took up just like a normal resistor?? wire in and go?
Old Nov 25, 2008 | 07:09 AM
Demon_ni2's Avatar
i wish i new that! ^^ then i would just grab some evo9 injectors.
Old Nov 25, 2008 | 07:31 PM
KillahB's Avatar
Older DSMs have resistor boxes, or you could just wire resistors inline with your setup. Hondas also had resistor boxes IIRC .... dont quote me on that though.
Resistors give you a much wider realm of injector choices, but realistically, you can find high impedance injectors at a reasonable price at typically cc ratings for most boosted applications here. ANyone looking at big boost is probably looking at some sort of aftermarket engine mgmt. which can accommodate the low impedance injectors.
Old Nov 28, 2008 | 12:32 AM
ThunderOZ's Avatar
so have you decided to go with them? I may since it seems like I'm not getting enough fuel right now...
Old Nov 28, 2008 | 12:42 AM
4g94T's Avatar
same here. Im running RC 370cc and I am leaning out 12.2-3 AFR at 4K rpms @ 10 psi with my values on ecuflash maxed out 7.4 i think...
Old Nov 28, 2008 | 08:44 AM
ThunderOZ's Avatar
So the ideal afr to shoot for would be in the 11s wouldn't it?
Old Nov 28, 2008 | 09:11 AM
4g94T's Avatar
Yup. 11.0 - 11.5
