turbo help.....wtf!!
Old Dec 19, 2008 | 06:32 PM
MurphDurph's Avatar
So I got my turbo put in, all lines connected and such..fired it up. All sound good till my overflow tamk started shooting out coolant. We killed it, cleaned the mess and noticed that the overflow tank was filled with some type of tannish sludgelike crap. So we emptied the overflow tank, and I started it again. My friend observed the overflow tank slowly filling. It ran idle for about 1min then it started to fill a lil faster, so I killed it. The overflow tank was filled with the tannish goop. I don't know if it was oil or not. It wasn't as thick and it didn't have a smell. I've asked a few other friends and I got maybe a blown head gasket or blown turbo. The car was runnin fine before I put it on and the turbo wasn't blown when I bought it. How can tell if the turbo is blown or if the head gasket is blown, if its either of those. Ill take pics tomorrow since its dark out right now. Any knowledge, advice, solutions, help are greatly appreciated.....
Old Dec 19, 2008 | 06:46 PM
hopper's Avatar
car was never driven with turbo?? I would reccomend getting a coolant pressure tester. see if your exhaust is pressurizing your coolant ( warped head/ blown headgasket)
Old Dec 19, 2008 | 07:13 PM
APEX'iEvoIV's Avatar
I would remove and check your spark plugs and also check the condition of your engine oil, make sure the oil/water lines to the turbo are correctly connected to the right fittings and go from there.
Old Dec 19, 2008 | 07:24 PM
hopper's Avatar
yeah you didnt cross your oil lines and water lines somehow did you?? Is your turbo liquid cooled?
Old Dec 19, 2008 | 07:36 PM
MurphDurph's Avatar
the turbo is oil and water cooled...im checking up on the lines now, but cant seem to find a good reference...would you happen to know which fitting they go into excatly?
Old Dec 19, 2008 | 07:38 PM
post up some pics mate
Old Dec 19, 2008 | 07:41 PM
MurphDurph's Avatar
im gonna post some pics up tomorrow cause its dark over here
Old Dec 19, 2008 | 08:19 PM
senate6268's Avatar
Here is the proper installation of the oil and coolant lines.
Old Dec 19, 2008 | 08:32 PM
MurphDurph's Avatar
Awesome, that seems to be my issue. Thanks a lot
Old Dec 19, 2008 | 08:40 PM
TTP Engineering's Avatar
Wow you plumbed your oil lines into the cooling system? Holy crap!
Old Dec 19, 2008 | 09:10 PM
Demon_ni2's Avatar
wowzors.. u really cross fead it.. ouch im glad my turbo is only oil feed. i would have probably done it to, cuz im retarded.! lol
that sludge crap is all up in your motor now to.. might wanna geta good coolant flush when you get it runnin right. and do another oil change, help get some of that water out. eeeek what a mess.
Old Dec 19, 2008 | 09:30 PM
MurphDurph's Avatar
Yea, that's what tomorrows plan is...a really good flush and oil change...a simple mistake that hopefully didn't cause too much damage. Another lesson learned...but on a good note, so far I have no other leaks
Old Dec 19, 2008 | 09:46 PM
OZR_Lancer's Avatar
da'am crossed lines..... i hope you dont got any damage bro....
Old Dec 23, 2008 | 08:01 PM
JRR's Avatar
JRR
luckily it was caught now and not later. just like u said clean everything out good and you should be good. just make sure you put some seaelnt tape on all connections to make sure nothing leaks.
Old Dec 23, 2008 | 09:30 PM
MurphDurph's Avatar
Yea, I took off my oilpan, wiped it clean, took off all hoses and pushed water thru. I've flushed my radiator twice and gonna do it again tomorrow. Everything is fine now. Although there is something else of an issue...my turbo makes a weird "rattling" noise, like there's a loose bolt when I'm coasting in gear. I checked for shaft play and there is none, so could it be the bearings?
