what could it be
what could it be
so know i get a new tdo4l, but im getting a problem, it is only in 2nd gear and up, when i reach like 4000 rpm it start like desaccelerating but not constant , it like for instants , in 1st gear it works fine. can someone help me, im pushing 7 psi. sorry about my english im form guatemala
I'm guessing you just installed everything and drove away. You need something to tune with. You need a piggyback fuel controller or ECU reflashing software. You might damage your engine if you don't tune your engine for fuel and ignition timing. You may also need larger fuel injectors if your stock injectors are at maximum IDC.
ok, yes im learning all this stuff, the are no much people in here that know very much about lancer, so it is kind of hard. about the bov it is ok know. the thing is that with the first turbo it work fine. could it be other reason before the tune?, i can figure that my air filter is already in bad shape, or maybe be the fuel pump?, im running stock inyectors.
ok, know are running well, no more trouble, just change the air filter and no more trouble it run good, it seems the old one was in very bad shape. thanks to the people that help. the mechanic check the fuel ratios and it all right know. thanks a lot.
04tarmacEVO
Nov 22, 2013 01:30 AM
raytrix
13
Jun 8, 2010 08:11 AM
powerjjang
20
Mar 13, 2008 11:21 AM
