02 lancer oz 16G Build
Old Nov 8, 2009 | 02:55 PM
  #31
*02Lancer*'s Avatar
lol o well it work's. say's walbro got to be better then stock even a 190 would work. I got a megan 3'' DP anyone know were i can ger the gasket that goes between it and the O2 dump.? would a stock one work? or does it need to be bigger since the pipe is 3''
Old Nov 17, 2009 | 07:02 PM
  #32
*02Lancer*'s Avatar
Need help trying to order my oil feed and im having problems!!! lol One said 1/2 inch 90 degree to - 6 an female -6an male to - 4an male. An anouther said I believe the hex fitting/plug on the oil filter housing is a 3/8 NPT. So you will need to reduce that to a 1/8 NPT which will fit the -4an female hose fitting. What one is it? It's for the thread above the oil filter the HEX bolt.
Old Nov 17, 2009 | 08:30 PM
  #33
JRR's Avatar
JRR
i dont remember i got mine from //rrm when i got the rest of my stuff
josh
Old Nov 17, 2009 | 09:48 PM
  #34
03lances's Avatar
Yes you have to get the stock one from the dealership I am running a full 3" DP with a stock 02 housing and stock gasket worked mint it was $17
Old Nov 17, 2009 | 09:52 PM
  #35
03lances's Avatar
I would suggest getting a oil sandwich adapter then have house of hose make you an oil feed line with a 1/8th NPT male end which threads right into the sandwich adapter, 4 feet long -4an female end and then get a 12mm banjo fitting with the -4an end to connect your oil feed to the turbo, mine looks soo clean and havent leaked a drop of oil.
Old Nov 18, 2009 | 04:15 AM
  #36
zulu989's Avatar
i found my receipt yesterday, ill let u know what i bought later this afternoon
Old Nov 18, 2009 | 07:23 AM
  #37
Sicktght311's Avatar
3/8NPT to -4an is the size you need to attach your -4an oil feed line to the plug on the oil filter housing. Check the interwebs for it
Old Nov 18, 2009 | 04:41 PM
  #38
senate6268's Avatar
http://www.slowboyracing.com/product.php?productid=2280
Old Nov 18, 2009 | 07:10 PM
  #39
*02Lancer*'s Avatar
sweet thank you very much! Almost got all the parts!!!! Pssssshhhhhh
Old Nov 18, 2009 | 07:30 PM
  #40
03lances's Avatar
What I like about my setup. Is I have my feedline ran below and behind all the belts just makes me feel a little better
Old Nov 18, 2009 | 07:37 PM
  #41
*02Lancer*'s Avatar
Yah I priced the sandwich plate but they a lot more than a fitting. I know you say your's does not leak, But most people i know who have one leak's. What brand do you have. And i hope with 4' of line i will be able to keep it away from my belt's.
Old Nov 18, 2009 | 08:13 PM
  #42
03lances's Avatar
Yup not a single drop I have just a glowshift one. For my whole feed line setup $30 sandwich plate $25 for custom made line from house of hose $12 for the stupid banjo fitting so $67 shipping and taxes included not too bad
Old Nov 19, 2009 | 03:43 AM
  #43
MurphDurph's Avatar
yea i got a regular ebay sandwich for $30 and the fittings i got off my ship i guess being an engineer pays off
Old Nov 19, 2009 | 10:41 AM
  #44
03lances's Avatar
Here is how mine looks, and since there is 3 ports I put my oil pressure sensor on the back one.
Old Nov 19, 2009 | 02:13 PM
  #45
steven121's Avatar
down pipe and o2 housing
what type of o2 housing and downpipe should I use for a TD05HR 16G 9.8T turbo with a wastegate?
and when I get these do I need to modify them to make it fit my exhaust system, or does it bolt straight on?
I got a 02 Lancer Es
