Turbo Problems
Old Dec 12, 2009 | 10:10 AM
03lances's Avatar
Wait so last I knew it was running but just running like crap right? But now there is no spark or fuel so its not running period?
Old Dec 12, 2009 | 11:30 AM
t3lancer2003's Avatar
right. The fuse that keeps blowing is called "fuse #1". The shop got power from an outside source to the fuel pump and everything started running again. Then they replaced the fuse and tried starting the car and the new fuse popped.
Old Dec 12, 2009 | 06:37 PM
Demon_ni2's Avatar
something is grounding out on your wiring harness more then likely.
Old Dec 12, 2009 | 09:35 PM
*02Lancer*'s Avatar
yep ^ he's right the only way you pop a fuse is if you have no load or not enough load in a circuit. So you are shorted to ground somewere.
Old Dec 12, 2009 | 10:18 PM
03lances's Avatar
+2, although I am assuming you are just going to let the shop handle it... if you decided to tackle it yourself you would want to start at the pump and follow the wiring harness all the way back checking for cracks, splits, bare wires or loose connections.
Old Dec 14, 2009 | 03:52 PM
Yeah, it's still at the shop, been there since wednesday.
Old Dec 14, 2009 | 04:03 PM
sLUg_'s Avatar
boost line to intake mani... that was my problem. sounds exactly the same
Old Dec 16, 2009 | 02:09 PM
It's not, it's electrical.
Old Dec 16, 2009 | 02:30 PM
03lances's Avatar
I think he was kidding If he wasnt then he needs a new mechanic. a boost line to the intake mani is not going to keep your car from running at all.
Old Dec 17, 2009 | 12:03 PM
Does anyone have a fuse diagram? I'm trying to figure out which fuse "#1" is.
Old Dec 17, 2009 | 12:52 PM
Got the fuse diagram, I'm giving it to the mechanics
Old Dec 26, 2009 | 02:28 PM
oznoobfabber's Avatar
any reputable mechanic should have that or know where to get it if you ask me
Old Dec 26, 2009 | 11:56 PM
03lances's Avatar
+1 the fuse diagram is in the owners manual for cryin out loud all vehicles have them in there
Old Dec 27, 2009 | 03:49 AM
and even if you dont have the owners manual like myself you shouldnt have to do the leg work for your mechanic ..... its part of their job
Old Dec 27, 2009 | 05:41 PM
Demon_ni2's Avatar
most all mechanic shops use "alldata" program. it has all that information in it. it included diagrams and 'how-tos" also
TLeid91
Apr 4, 2016 07:43 AM
hooliganSKATE
Aug 17, 2015 03:30 PM
AFmatt15
26
Oct 18, 2012 01:09 AM
TRASHY_GTS
Toronto Lancer Club
27
Nov 28, 2010 08:52 PM
GearDownSon
18
Jul 18, 2008 12:51 PM
