4g63 in a US lancer?
Old Jun 6, 2002 | 04:10 AM
b_tapper's Avatar
So can a fwd 4g63T engine be swapped into a lancer? Let's just say cost isn't a factor.
Old Jun 6, 2002 | 04:13 AM
Lan Evo's Avatar
b starts to sounds like a n00b, are you alright?
Why don't you read that FAQ I put together?
Old Jun 6, 2002 | 04:15 AM
pjal84's Avatar
Does it cover the FWD models though?
Old Jun 6, 2002 | 04:16 AM
b_tapper's Avatar
Where? and I'm talking FWD beotch
Old Jun 6, 2002 | 04:25 AM
Lan Evo's Avatar
Aight, the FWD 4G63T only available in 1/2G DSM, not on EVO. The engine configuration for the DSM with tranny is totally different than that of the 5G Mirage and the new Lancer. If you're determined to have the DSM's FWD engine to work in a Lancer, prepare to re-weld all the motor and tranny mounts and relocate most of the things in the engine bay then
The 1/2G 4G63T (engine only) has the same configuration of EVO I-III ones.
[EDIT: to get the fact straight for the DSM]
Old Jun 6, 2002 | 04:26 AM
GPTourer's Avatar
FWD of course!
Of course you're talking FWD` what AWD Mirage/Lancer would
there be without a turbo 4G63 under the hood in the US? His FAQ
covers the swap you're talking about.
Old Jun 6, 2002 | 04:29 AM
b_tapper's Avatar
So it's just like doing a honda engine swap. So it can easily be done, if you have a little skill
Old Jun 6, 2002 | 04:33 AM
Lan Evo's Avatar
I would say a lot more than "a little" the 2G engine is 180 degee "turned" compared to the Lancer's engine. so you will have to relocate prob EVERYthing (A/C, PS, etc....). You will need new axles, ECUs, sensors, upgraded fuel system...yadda yadda yadda...
Old Jun 6, 2002 | 04:35 AM
pjal84's Avatar
Awesome info Swap Guru. It's a shame the damn engine have to be turned as such. Probably cheaper to buy a Mirage with the appropriately turned engine and then pull of the swap no?
I'll probably add this to the existing FAQ to Lan. Excellent work.
b_tapper's Avatar
Like I said a little harder than a honda swap. Powersteering and a/c isn't needed. Gotta do half that stuff with a lot of honda swaps anyways
Old Jun 6, 2002 | 04:36 AM
Lan Evo's Avatar
Let me put it this way, it would be much much easier (relatively speaking) to do an EVO I-III replica IMO....since the 4G mirage has the same engine cofig compared to 1/2G DSM....and parts will be easier to fine with all those DSMs out there
Old Jun 6, 2002 | 04:37 AM
b_tapper's Avatar
Wait so a fwd 4g63t will fit in a mirage?
Showing how little I know about swaps
Old Jun 6, 2002 | 04:39 AM
Lan Evo's Avatar
In fact, it has been done AND it's AWD!!!
Little EVO
Old Jun 6, 2002 | 04:40 AM
GPTourer's Avatar
Do what?
All 1G Turbo DSM are AWD.
Err, no. There are 1G FWD Eclipses, Talons and Lasers.
What's a 2G IIRC?
Old Jun 6, 2002 | 04:42 AM
Lan Evo's Avatar
IIRC = If I Recall Correctly
Aight, so I stand corrected, thanks
