**** it.. turbo build
Old May 23, 2010 | 10:55 PM
steven121's Avatar
Originally Posted by crf inc.
well if you have an evo ecu then you already have 2 step. every evo ecu is programed with 2 step. its just a matter of setting the rpm you want 2 step to kick in at. its actually called a stationary rev limiter. when you pull up your rom on ecuflash you have to open the table called stationary rev limit. by changing that number you are changing what your car rev limits itself at when your car is sitting at a complete stop. i currently have my limit set at 4000rpm.
So basically thats when your stationed and when your driving you can pull as many rpms as you want... pretty sick when I get this ecu flashed im going to have to do that!!!
Old May 24, 2010 | 12:36 AM
_801_'s Avatar
lancer looks great,
Old May 24, 2010 | 01:34 AM
MurphDurph's Avatar
so my tune date is scheduled for may 31st, memorial day. paul at yimi sport sounds pretty excited to tune my car and im expecting some good numbers from one of the best ecuflash tuners on the west coast. i will post up some dyno sheets as soon as i get them . i have a few updated parts as well. i picked up and installed an evoVIII ecu, jdm evoX map sensor and an innovate lm1 wideband. the car runs beautifully with the evo ecu and ive just been doing some n/a data logging. been messing with the 2 step a lil bit too and im pretty excited to try it out with the slicks once im boosted. my goal is to be in the mid 13 second range right after tunning.
so the kit should be on sometime before the 31st rite?
Old May 24, 2010 | 11:23 AM
Lusion's Avatar
Most definitely
Old May 24, 2010 | 07:04 PM
crf inc.'s Avatar
Originally Posted by _801_
lancer looks great,
thanks man!
yessir! actually the kit is already on(= ill post up a couple of pics in a minute.
Old May 24, 2010 | 07:30 PM
crf inc.'s Avatar
new pics in first post
Old May 24, 2010 | 07:33 PM
buchnerj's Avatar
Car looks great. No A/C or power steering on a daily driver in southern california. Ouch. Tough sacrifices for power. Nice little build though for sure.
Old May 24, 2010 | 07:43 PM
crf inc.'s Avatar
thanks! wasnt really a sacrifice though, more of a personal preference..lol i never use a/c anyways, i roll with the windows down. and ive have plenty of cars with no power steering, it just means everybody's gonna have to buy tickets to the gun show... hahaha
Old May 31, 2010 | 04:08 PM
crf inc.'s Avatar
Update...
Ok so today I got my car dyno tunes and I'm very satisfied with the numbers. Ill post a dyno graph when I get home. I'm at 204HP and 213tq at around 10-11psi.
BUT... I'm having an issue with my crank case pressure. I keep blowing my dipstick out and spraying oil all over my engine bay. I do have one of the pcv valves capped off so I think that may be the reason why my crank case pressure is so high. in thinking if I open up that pcv valve it should drop the pressure back down. Has anyone else had this problem? I'm gonna put a oil catch can on soon anyways, but does anyone know if this will solve my problem?
Old May 31, 2010 | 06:23 PM
Demon_ni2's Avatar
my dip stick use to shoot out also.. i just ziptied mine so it cant get shot out.. i never had oil backing out of the dip stick.... but all my pcv vents blow oil pretty bad, i have them all tied into a breather/catch box now to atmosphere (and blocked all the connection points to the intake side so there arent any vacume leaks)
Old May 31, 2010 | 06:29 PM
Boostedlancer$'s Avatar
yah man i had the same problem what i found is that when i installed my new pisont and rods that the rings lined up and created pressure and shot out the dipstick. i broke 3 of those stupid things. so when i rebuilt my motor and made sure my piston sings were not lined up and i havent had the problem since.
Old May 31, 2010 | 09:22 PM
steven121's Avatar
ok so when I get turbo what do I need to secure to prevent anything from blowing out or leaking?
Old May 31, 2010 | 09:54 PM
vityenyka05's Avatar
so ur na, just a turbo kit slap on with the injectors and a evo ecu and evo 10 maf..??
thats pretty intense
Old May 31, 2010 | 10:17 PM
link62's Avatar
not evo 10 maf, its a map sensor to read boost
Old Jun 1, 2010 | 12:00 AM
crf inc.'s Avatar
got my crank case pressure figured out. it was the cap i had put on one of the pcv valves.. just lemme say theirs two of them for a reason i guess.. i still need to get an oil catch can but im just venting it right now.
