DOHC 4g94--BOOSTIN'
Old Apr 17, 2010 | 12:58 PM
  #61
bignasty_yagn's Avatar
the wiseco pistons, still don't fit, even after soaking in oil.. they are too snug, and dont fit in, but it will be bored on monday. 1/1000 inch, just enough to fit. ill have pics up eventually of the pistons and the fittings
its finished!!! new block too haha jk just me being bored
but build will be paused. the bore job will be done tomo, and the head will be ported on monday. Also the valve cover will be ready for paint. (i am an art student, so be prepared for somethin nasty haha)
Old Apr 17, 2010 | 01:11 PM
  #62
MurphDurph's Avatar
Attachment 150774
but build will be paused until monday, after the bore, and port job.
dont worry i'll keep yall posted
did you put oil on the cylinder walls and are you using a ring compressor?
Old Apr 17, 2010 | 01:17 PM
  #63
yes.. cleaned it out and everything, still too snug
Old Apr 17, 2010 | 01:22 PM
  #64
MurphDurph's Avatar
another thing about the rods, they are much thicker than stock (obviously) therefore youre gonna have to trim about 1/4 in grooves at the bottom of each cylinder, front and back otherwise the rods willl come in contact with it and stop its rotation
Old Apr 17, 2010 | 01:26 PM
  #65
alright thanks for the info
Old Apr 17, 2010 | 01:29 PM
  #66
MurphDurph's Avatar
i know it sounds weird, but you will know what im talkin bout when you get them installed
Old Apr 17, 2010 | 02:40 PM
  #67
steven121's Avatar
Attachment 150774
uh oh its back to the flintstones, he got that 2 foot horsepower
How much left do you have till ur build is complete
Old Apr 17, 2010 | 06:15 PM
  #68
Well we gotta bore out room for the pistons. Install the the pistons and rods. Port the head. Bolt on the head. Install cams. Adjust pulleys and timing. pretty much build back up. Adjust and install fuel delivery. then mock up turbo kit. Install turbo kit. Do some custom fab. And install gauges. And then tune. so hopefully a week or so. (probably missin a couple steps. But its a long list. also im in class till 6 every day. so i wont be able to update as fast.
Old Apr 18, 2010 | 06:43 AM
  #69
llt-racing's Avatar
?????????????????? how did you get the head you said monday. However glad you recieved it love that pic hahahahhaaaa...
where is pics of pistons?
wow nice manifold what is that lor?
Old Apr 18, 2010 | 08:29 AM
  #70
sorry i forgot to tell you. I drove around my neighborhood for an hour, following mailboxes with the flags up. I tracked down the mail man and got the package. I was too impatient ha
Old Apr 18, 2010 | 08:36 AM
  #71
and the mani. Is a custom mani. A megan tubular turbo mani but w/ a 4g94 flange. My dad cut and welded it. Will have pics of pistons today
Old Apr 18, 2010 | 08:51 AM
  #72
llt-racing's Avatar
damn can your dad push out more? I got a customer in india that needs a turbo manifold and i dont want him to make his own. what you reckon hmmm about the post man lol more pics bro bigger ones and more detailed ones
Old Apr 18, 2010 | 09:59 AM
  #73
senate6268's Avatar
Sorry to break it to you, but your manifold is going to crack. Every single person (myself included) that took a 4G63 Megan manifold, cut the flange off and welded a 4G94 flange on has ended up with a cracked manifold. The distance between the inner runners and outer runners is too great and puts too much stress on the existing welds.
Old Apr 18, 2010 | 11:10 AM
  #74
well poop sticks. What am i suppose to do? get a new mani? The RRM one, do u have to get a external WGA? I dont want my forge adjustable wga, to go to waste
Old Apr 18, 2010 | 12:35 PM
  #75
Demon_ni2's Avatar
^^ thats actually very common with MOST cars that are built when u upgrade to much larger rods, alot of cars dont have the clearances, but simple fix, we Plasma'd my block and head apart so we could see all the water passage ways, so we knew exactly how much clearance we could make (also to see how much we could port n polish)
calm, for now, ur manifold will work, but it will not last long.. u will need to start looking into having one custom built for ur car(yes, and it is expensive) but american stainles weld Ls and hand(and some machine) welded manifolds are MUCH MUCH better and stronger then what megan and other eGay knockoff companies make..
simply put, start checking around for a local fabricator that has the knowledge that can build a manifold for you that will do your car justice! (plus, MOST fabricators, garentee all there work, so if something they build does crack, they will fix it!)
oh.. and a custom manifold, with ur turbo setup, will work just fine with ur forge wga.. no need to go external since u have an internally wastegated turbo that will work just fine.
