Project Blackie GTS Complete
Old May 22, 2010 | 07:07 AM
  #61
GTS08's Avatar
Originally Posted by henryDgreat
thanks for confirmation!
no prob but the spark plugs Fit I thought they dont but I already checked on NGK page and the part number on lancer evo x and GTS match the same
Old May 22, 2010 | 11:15 AM
  #62
lancer2008's Avatar
So instead I am buying RA turbo and starting of with that. Once I swap my internal parts I will upgrade the turbo. And I am only spending so far $750. Beats 4200 RRM
Old May 31, 2010 | 08:55 PM
  #63
GTS08's Avatar
what ever you do its good as long as you are pleased with the results and if those results feed your needs good luck with the decision
Old Jun 10, 2010 | 04:50 PM
  #64
superlancer80's Avatar
anything on the kit yet is it tuned?
Old Jun 12, 2010 | 08:28 AM
  #65
lancer2008's Avatar
I would like to know what ECU maps did you use for the tune. Putting the pipes together is half of the battle. Now I am concerned about the ecu tune.
Old Jun 13, 2010 | 05:40 AM
  #66
GTS08's Avatar
the car will be tuned finally this Tuesday at night, hopefully we will see some numbers and how much it produces but to be honest with you I just like the fact that the car is turbo , Im saying this because the purpose of this project was to add the turbo just for sound and a little power but not for racing reasons
Old Jun 13, 2010 | 05:41 AM
  #67
GTS08's Avatar
a friend of mine is helping me on that one all I know is that he is a good tuner for sure
Old Jun 13, 2010 | 07:00 AM
  #68
p1llar's Avatar
Sick setup up.
Major props to you for piecing it together on your own. I'm going to attempt this over the winter, using a mixture of evo and raillart parts.
Old Jun 16, 2010 | 09:45 PM
  #69
GTS08's Avatar
Originally Posted by p1llar
Sick setup up.
very nice good luck with the project any help you need im at your service!
Old Jun 30, 2010 | 11:16 PM
  #70
Lancer09mx's Avatar
what kind of clutch do you have in your car ?
Old Jun 30, 2010 | 11:25 PM
  #71
yitzac1990's Avatar
Act mr1-hdg6
Old Jul 1, 2010 | 12:02 AM
  #72
Lancer09mx's Avatar
I didnt see that your car is GTS, do you know a good one for a ES ? Im going turbo soon (next month) and I have to change my clutch.
Old Jul 1, 2010 | 04:07 AM
  #73
EngRWW33's Avatar
^^Same transmission, so same clutch will work.
Old Jul 1, 2010 | 07:33 AM
  #74
GTS08's Avatar
about the clutch me and yitzac have the same one he mentioned ,.
-Yes my car is a GTS but 2008 which is is the same engine as the ES o go for it you will not regret it believe me!, remember you have to do gas return line because the fuel rail of the lancers is not like the evo you will have to adapt a furl pressure regulator in order to have a good mixture of gas
Old Jul 1, 2010 | 07:35 AM
  #75
GTS08's Avatar
there is one clutch the name is Spec performance those guys made one kit specifically for the lancer I would recommend that one to you
