Project Blackie GTS Complete
Old Nov 17, 2010 | 05:30 PM
  #106
Destin_sinner's Avatar
isn't our rods forged??? i though that what needed to be reinforce was the pistons??? About the sleeves i saw some darton ones somewhere around 600 or something but they were for evo x... would that fit our short blocks??? And will that help with the problem of our short blocks.( u know that they are open deck and cant handle to much psi because they are hollow around the cylinders)
Old Nov 17, 2010 | 07:08 PM
  #107
yitzac1990's Avatar
yeah our rods are forged, but they're small. I know theres a company that sleeves 4 cyl. blocks for about $1200 total, including sleeves. You just have to ship them your block
http://www.larryspower.com/engine/Sleeves.html
Old Nov 19, 2010 | 06:34 AM
  #108
GTS08's Avatar
Originally Posted by yitzac1990
congrats on the numbers! aboutt he internals, the evo X rods wont fit our motor, the diameter of the big end of i think 6mm smaller on our motor. pistons will fit, but you need custom rods. also look into a thicker head gasket to lower the CR. let me know what you do with the internals! I want to do mine eventually...I also suggest, if you have the money, you get your block sleeved.
Thanks ill take that into consideration!
Old Nov 20, 2010 | 06:48 PM
  #109
1200 for the job including sleeves is not bad at all. Its a pretty good price. Besides taking under consideration that the darton sleeves would fit our block i guess the block will be able to handle between 12 and 17 psi with no problem or perhaps more. BTW does anyone knows where can i buy a 4b11 short block with paper our documentation of ownership???
Old Nov 20, 2010 | 07:42 PM
  #110
BTW guys here is another turboed lancer from PR tunned by Ruben of Dyno Center to 380whp 379TQ at a peak of 24psi settle in at 21psi with the only mods made to the engine are stock evo x pistons and rods. Still with the lancer crankshaft .
https://www.evolutionm.net/forums/la...ynocenter.html
Old Nov 23, 2010 | 06:00 AM
  #111
GTS08's Avatar
The internals are not only from a evo x the upper block is also evo x the problem with this is the rods the evo x ones are way to long
Old Nov 23, 2010 | 09:27 AM
  #112
Thats odd they havent mention that the upper deck is from a evo x. Ruben and other guys have mention that it only have evo x rods,pistons, manifold and turbo set up. Crankshaft and everything else remains from the lancer with the exeption of the bolt ons that are obviously from evo x. Im sure they must have evo x injectors and fuel rail as well. What is not clear for me is what clutch they are using? an evo x or lancer ACT?? since the lancer one is good for 333 lb/tq or something near it. And he is making way too much torque for that clutch to handle.
Old Nov 26, 2010 | 07:04 PM
  #113
GTS08's Avatar
Dont be silly my friend think about it,the evo x pistons can fit the n/a engine because both are 86mm but the rod of a evo x is way longer for me its just bluffing to say they are using a stock n/a engine with evo x internals I dont buy that speech, back to topic Im selling evo x fuel rail oem if you are interested let me know and for those who are interested on making,they're lancers turbo go for it its fun specially if you fo it yourself! The rest will be to ongoing battle between who has the most whp for me the most important part of a proyect is to gain a lot of power with less work and psi of boost , in that way you can tell if your car was tunned by a real tunner.Then youll be satisfaied .
Old Nov 30, 2010 | 01:16 AM
  #114
Nightwingthief's Avatar
Hi
Well done on your build A++ Awesome
I am assembling my own kit and was wondering if you upgraded your fuel injectors?
Old Dec 19, 2010 | 08:42 PM
  #115
GTS08's Avatar
Yes, I do have the evo x ones
Old Mar 26, 2012 | 03:14 PM
  #116
cky_2k's Avatar
Hey, what short ram intake did you use ?
Old Mar 28, 2012 | 10:44 PM
  #117
tougewreck2's Avatar
looks good man
Old Sep 25, 2013 | 05:59 AM
  #118
GTS08's Avatar
Nop it's custom
  #119
GTS08's Avatar
Originally Posted by tougewreck2
looks good man
Thanks !!!
getsideways
Midwest Region
Jan 29, 2011 06:43 AM
kataklyzm
Jan 9, 2011 12:04 AM
Gary 805
Jan 8, 2011 07:01 AM
OverBoostedEvo
Oct 13, 2010 08:47 PM
CraigWilcox
Jul 12, 2010 07:28 AM
