Project Blackie GTS Complete
Old Sep 26, 2010 | 02:11 PM
  #91
Evo10HKS's Avatar
Originally Posted by INJEN///
hola blackie gts tengo un kit de evo x original y necesito consejos en el campo de la gasolina.
tengo injectores de evo x.
la flauta de fabrica me brega pa turbo sin tener que adaptarle un regulador de gasol?
se supone que la ECU controle la gasolina pero si necesito una walbro 255?
si la ECU controla la gasolina porque le meten regulador con flauta racing y retroseso?
el limp mode bueno aqui hay una duda si yo pongo el carro a 3 libras sin setear como quiera me tira limp mode? i mean no puedo boosterarlo o simplemente paseando pega a tirar la senal? es que tengo planes de usarlo a poco libraje antes de llevarlo a setar en dynocenter ruben es mi carro uso diario u know... se te agradece algun tipo de info. esta nice tu projecto by the way....
as stated in the rules, this IS a ENGLISH speaking forum.
Old Sep 27, 2010 | 01:34 PM
  #92
08blueGTS's Avatar
nice ride...did you use the stock manifold? wat else did u have to buy? turbo brand?
Old Sep 27, 2010 | 08:48 PM
  #93
GTS08's Avatar
Bought the custom manifold, and about the turbo its a t3t4 turbo xs power works great for the price!
Old Oct 9, 2010 | 12:39 PM
  #94
lancer2008's Avatar
Hey GTS08,
I know you said you used ecu flash. What changes did you make to the maps. I have the program but not that sabby when it comes to ecu flash. Any help would be great.
Old Nov 13, 2010 | 06:11 AM
  #95
GTS08's Avatar
Ok this are the results of the.dyno.pull at.sporty's thanks to junot tunning from Puerto Rico @ 4psi the car pulled 232 whp, at 6 psi the car ran 267 whp not bad for a 6psi car but still we aee working our tunning on going 300 at the same 6 psi
Old Nov 13, 2010 | 06:14 AM
  #96
GTS08's Avatar
Ill be posting the dyno chary shortly but my phone does not allow me to paste the link and the video from the dyno at yotube thanks for the support!
Old Nov 15, 2010 | 10:06 PM
  #97
Destin_sinner's Avatar
Dude those are some good numbers... y eso q el RRM kit is set at 9psi if im correct and just gets 230 whp or something near that. Im planning on boosting mine and was considering going the evo x set up but im stuck on the problem with our open deck short block( the cant handle too much psi).. So i just though of buying an evo x short block but my first problem dont know if the cylinder head of our car will fit( obviously planning on buying some evo x cams spring and retainers injectors fuel rail fuel regulator etc...thats thinking that they will fit) and my second problem is that i dont know if the evo x short block will fit our transmission... Any help would be appreciated
Old Nov 16, 2010 | 06:52 AM
  #98
GTS08's Avatar
Forget about all that get some nice tunner! There is a lot of confusion out there about the kit, forget about the evo x parts too go custum like I did!your car does not need any evo x turbo kit to function all of the parts are generic parts you just need to adapt them thats all the only way I worked my kit out was to "imitate" the way the parts are placed on the evo x the rest is history , if you need any help feel free to pm me
Old Nov 16, 2010 | 07:00 AM
  #99
GTS08's Avatar
Here.is the dyno chart:
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs1145.snc4/148735_456060404388_582949388_5633238_6064958_n.jp g
Old Nov 16, 2010 | 11:28 AM
  #100
Well thats very impressive... for just 6.4 psi 267 whp is more than someone can expect... Well JUNO is JUNO so what can I say....but correct me if im wrong you can still raise it to 9 psi which is what i remember the limit to our cars right?? is just that im aiming between 300 and 350 with that i'll be happy. BTW do you use yours as a DD?? How's the MPG?? Another question, you achive this with stock internals??? and without porting or anything??? Thanks y q lo difrutes y papa dios te lo deje gozar.
Old Nov 16, 2010 | 01:00 PM
  #101
kraven9's Avatar
Not bad at all. Pretty nice numbers.
Old Nov 16, 2010 | 04:00 PM
  #102
GTS08's Avatar
Thanks my car is stock internals,we did not went all the way to 9 psi because I wanted to get as much numbers with the lowest psi as posible but yes your car can touch the 300bhp the question is if the engine holds and I was not expecting to be the one bleweing up the engine,mpg is fine it runs 36 mpg on highway 32 on city, beleive me im pleased with the results but youll see some more numbers in december ill give it a try to make as much bhp as I can with the same engine better internals, btw are you from PR?
Old Nov 16, 2010 | 07:45 PM
  #103
You bet I am jajaja im from Caguas... I use to have a blue evo 9 with 400whp at 25psi but i sold it and now i miss that power so i just want to have something to give me a feeling that can compare a little bit to what i had. So im looking for a good and reliable set up for my car since is my DD. BTW Where are you planning on getting the internals??? Who made you the custom manifold???
Old Nov 17, 2010 | 02:38 AM
  #104
GTS08's Avatar
Thats crazy evo for a lancer! Anyways the internals ill be getting the evo x JE pistons or something alike ,the 2.0 engine has the same bore meassures in both engines,the manifold Taller nolin did it no regrets at all one of the few that helped me a lot on the proyect!!
Old Nov 17, 2010 | 10:53 AM
  #105
yitzac1990's Avatar
congrats on the numbers! aboutt he internals, the evo X rods wont fit our motor, the diameter of the big end of i think 6mm smaller on our motor. pistons will fit, but you need custom rods. also look into a thicker head gasket to lower the CR. let me know what you do with the internals! I want to do mine eventually...I also suggest, if you have the money, you get your block sleeved.
