Big turbo problem
Old Nov 10, 2003 | 12:01 PM
  #31
TURBOit's Avatar
if you cracked your cylinder wall well your screwed, chances are it sounds like you may have bent a valve or rod, possibly damaged a ring landing
Old Nov 10, 2003 | 12:36 PM
  #32
HobieKopek's Avatar
Welp, there's no accounting for the unexplained. G'head and tear the ***** apart or take it to a shop.
Old Nov 10, 2003 | 12:47 PM
  #33
jamie's Avatar
my only regret or warning if your going to drop 3000grand on a turbo spend another 400 or so and have a shop do it that way if a problem that was out of your control happens they are liable.that ***** was fast though.
Old Nov 10, 2003 | 03:40 PM
  #34
jamie's Avatar
#3 piston very little damage forged pistons on the way.they are going to dyno it and double check my install and the fuel air ratio and boost.at least it will be a little faster when iget it back.
Old Nov 10, 2003 | 04:15 PM
  #35
TURBOit's Avatar
not bad not bad, i need new intake and exhaust valves, but other than that, and buying myself an egt and boost gauge and i think ill be set
Old Nov 10, 2003 | 06:21 PM
  #36
Waggi32's Avatar
sorry i havn't gotten the pictures psoted yet i have been at school and work all day. when i looked at the engine i noticed that i will be needing a couple new parts the most expensive being the wiring harness that goes to the sparck plugs and the water pump and such things like that. Half of it was burned to peices. I just got off the phone with a company close to me that said that he would be able to get all the parts i need and design a new return pipe for me that is one peice instead of two plus dyno the car and see if it is running lean. He is also going to double check all my work and make sure everything else is properly set up. Now my job is trying to see if i can find the parts i need from other totaled cars cause i would love to save money. the harness that i need i am thinking mitsu will charge me at least $700 for so i am hoping to find someone on the forum with a totaled lancer that i would be bale to get the harness from for a lot cheaper. i think i may run and take a picture of the car but i don't know how good it will be since it is dark. I'll post a pic if it turns out good enough.
Old Nov 10, 2003 | 06:28 PM
  #37
Waggi32's Avatar
does anyone know someone willing to sell parts from a totaled lancer? if i can get these parts i will hopefully be able to save a lot of money. thanks to everyone for the help
Old Nov 10, 2003 | 06:37 PM
  #38
stygiosracing's Avatar
i am looking at turboing my lancer and am not worried by these posts. half of these people are doing installs themselves and are having to replace the pistons, which i am assuming are stock. not to dis anyone, but from what i have seen on this forum is that the pistons are the weakest link in our car. i will not turbo my car until i get my pistons. i am also not getting the RRM turbo kit. just found a better one.
Old Nov 10, 2003 | 07:06 PM
  #39
ronsozlancer's Avatar
Who here has had a turbo installed by Rock or RRM if they do them and have you had any problems?
Old Nov 10, 2003 | 07:47 PM
  #40
Waggi32's Avatar
here are a couple pics
Old Nov 10, 2003 | 07:48 PM
  #41
Waggi32's Avatar
one more
Old Nov 10, 2003 | 07:49 PM
  #42
Waggi32's Avatar
and one more
Old Nov 10, 2003 | 08:03 PM
  #43
Boni's Avatar
damn that doesn't look to pretty.
Old Nov 10, 2003 | 08:16 PM
  #44
ryancb's Avatar
ick
Old Nov 10, 2003 | 08:31 PM
  #45
OZRacer66's Avatar
Hey stygiosracing who are you getting your turbo from?
