My turbo lives again!!
Old Jun 23, 2010 | 08:48 AM
  #76
GTS08's Avatar
Originally Posted by hmoobher
what were the numbers?
look the end of the vid
Old Jun 23, 2010 | 08:50 AM
  #77
GTS08's Avatar
nice numbers !!! keep it up I got mine tuned but I got a bit scared , the wastegate spring was a 18 psi set, and im having problems with the fuel pump so ill post some nice vid too good luck bro!seems we are the only ones representing turbo lancers jaja
Old Jun 23, 2010 | 01:08 PM
  #78
yitzac1990's Avatar
thanks man! what wastegate do you have? get a Forge and call them and ask for the small 5 lb spring, its like 14 dollars shipped or something. good luck!
Old Jun 24, 2010 | 08:33 AM
  #79
GTS08's Avatar
thanks actually is worse than that it seems I may have to get a evo x fuel rail to make the return line for the gas from the pump to the fuel rail which I dont have installed but that was the problem and the spring thanks again ,!! long live the n/a turbocharged lancers!!!jaja
Old Jun 24, 2010 | 08:53 AM
  #80
yitzac1990's Avatar
try using an evo x fuel pump
Old Jun 24, 2010 | 09:42 AM
  #81
THEevo8urV8's Avatar
nice lancer tho man
Old Jun 24, 2010 | 01:49 PM
  #82
yitzac1990's Avatar
thanks man!
Old Jun 25, 2010 | 08:06 AM
  #83
GTS08's Avatar
I have the wallbro 255 lph fuel pump but I solved the problem!luckily a friend of mine sold me his evo x oem fuel rail in 30 bucks !jajaja im such a lucky guy the only thing was missing was the fuel pressure regulator and I had one universal at home so only the spring for the wastegate and ill be ready to roll this week ill let you know the numbers! hope to touch the 250 at the wheel
Old Jun 29, 2010 | 09:48 PM
  #84
Evo10HKS's Avatar
nice numbers
Old Jul 2, 2010 | 11:13 PM
  #85
RockmanX's Avatar
just told my friend about this kit he is highly intrested in buying it im linking him to your thread
Old Jul 3, 2010 | 12:20 AM
  #86
uaserge's Avatar
Hey nice set up, I am the friend that RockmanX is talking about, i got 09 gts with 2.4 liter engine tho.
Old Jul 3, 2010 | 04:28 PM
  #87
RockmanX's Avatar
yea what about a turbo kit for that hommie?
Old Jul 3, 2010 | 06:53 PM
  #88
yitzac1990's Avatar
everything should basically bolt right up, except for the water feed line. that, you would need soem extra stuff for, a T adapter and thats about it because the 2.4L engine has an extra water line that uses the same spot I use for my water feed for the turbo
Old Jul 3, 2010 | 08:42 PM
  #89
RockmanX's Avatar
you can get and add this to the kit? turbo would spool faster as well
Old Jul 4, 2010 | 05:05 AM
  #90
dambreeze's Avatar
Nice work. I plan on doing the same as well. Thanks for all the info!
