Aftermarket radiator for turbo lancer
Old Oct 17, 2011 | 05:39 PM
corndog17's Avatar
My stock radiator has a huge hole innit. What radiator do u guys suggest getting to replace it? Mishimo 26in dual row aluminum? What will be an easy fit? Thanks guys.
Old Oct 18, 2011 | 10:15 AM
slatermvp's Avatar
one is running a megan, another an evo 4/5/6 mishimoto one I think, another has a stock evo 8 radiator. Different possibilities and each has its own pros and cons.
Old Oct 18, 2011 | 02:51 PM
corndog17's Avatar
So a mishimoto for a Evo 4/5/6 work alri. Probably the one I'll get thanks.
Old Oct 18, 2011 | 03:27 PM
Green_Bandit's Avatar
Your not turboed so clearance shouldnt be an issue for you. To keep it as simple as possible Id probably go with the OEM Evo one which you might be able to find here cheap.
Manual or Auto?
Old Oct 18, 2011 | 05:26 PM
03lances's Avatar
I have an all aluminum evo 5 radiator. This moves the top outlet well clear of the exhaust manifold incase of fitment issues like I had. Clearance is crazy close like 1/4" or less from my wastegate flapper but no issues hitting although I am not going to launch until I get solid motor mounts in.
Old Oct 19, 2011 | 05:10 AM
corndog17's Avatar
It's a manual and I do plan to go turbo after I break the motor in I m just running the stock manifold as of right now.
Old Oct 29, 2011 | 09:12 AM
krisgoodwin84's Avatar
I had a crack also and I ended up getting the mishimoto evo radiator and it fit fine install was easy. Works good and looks a lot cleaner
Old Oct 31, 2011 | 07:18 PM
HornstarBU's Avatar
I'm in the same boat as 03lances, WGA arm is about 1 inch from the radiator. I have polyurethane mounts though, so it's a lil stiffer.
My radiator was 100 bucks on ebay from kospeed...I'm very happy with it. Temps stay at a solid 195 degrees even in very hot texas heat with the a/c on in traffic.
TeRoy EvoIX
Oct 21, 2013 05:15 PM
IXmr321
17
Jul 24, 2013 01:12 AM
Brigganator
Apr 16, 2013 08:19 PM
lancer evo9
Oct 29, 2012 10:01 AM
ogrenator
Aug 20, 2012 01:11 PM
