RRM cam review
RRM cam review
Anyone that has an RRM stage one cam please chime in on your experience after installing this cam, idle, power-band, drive-ability. I just upgraded to the rrm camshaft everything seems fine except for a rough low idle.
i would move the crank til cylinder 1 is at top dead center and aligned with the timing mark behind it, then i would make sure the timing mark on the camshaft sprocket lines up with the timing mark. i used the straight edge of a razor blade to align with the timing mark on the camshaft since it was at an angle.
I just pulled the crank pulley off the motor and check the timing marks on the camshaft sprocket and the crankshaft, they seem as close as they did when I did the timing belt. Zulu said the cam was originally an RPW and then told me right before i made the deal with him it was actually an RRM camshaft which seems odd. I had to adjust the idle up a ways to about 900 rpm. At 650 - 700 the whole engine bay is a rattle box. Might go back to stock cam.
I had trouble trying to get Ryans car to idle right with the stage 1 cam. It wasnt bad per se but just a tad rougher than mine. When I put his stock block back together last week I also put his stock cam back in so never really got a chance to see if Aaron down at ER was able to get it to idle smoother. Idles great now but yeah stock cam and much different tune than before.
Sir Lancelot
Lancer Engine Tech
120
Mar 2, 2005 04:32 PM
