Do you know what type of piston you put in your engine because i will buy it and they say to there are 3 types of piston
Type A
Type B
Type C
Can you bring to me what type are the piston you buy and where you buy it?
Type A
Type B
Type C
It's supposed to be stamped on the engine somewhere but I had no access to see that so I took the B. Anyway when you buy aftermarket pistons, you don't have usually the choice. There's not much a difference between those sizes anyway.
Hey Everyone. We've got a few guys boosting some lancers with some serious power over on Facebook group Mitsubishi lancer turbo club. Two of them running SRT-4 Pistons setup pushing well over 300WHP and I'm in the process of putting in a 4B11T with a big 3582 Turbo getting ready for spring 2020! Come join us and find out what we're up to there.
Cheers
hey guys! can anyone share their tuned or base ROM for their turbo lancer? i'm curious to see how you guys dealt with the different issues in tuning evo x roms to fit boosted lancers and or stock lancer roms to accomodate boost.
Here is my 2009 Lancer GTS 2.4l 5 speed Turbo Project:
Parts installed:
Caliber srt4 Pistons and Rods + Rod Bearings
Caliber srt4 Cylinder Head Gasket
Evo X ARP Head studs
Evo X ECU
Evo X turbo and manifold
Evo X Injectors
Evo X Fuel Pump
Evo X Intercooler and piping
Evo X modified down pipe
Evo X top radiator hoses
Clutch Masters FX400
Evo X Blow Off Valve
Kinugawa Evo X Waste gate actuator with 1.2 bar spring
Ralliart modded air Intake
Custom 2.5" exhaust with evo x muffler + Electric Cutout.
317HP @ 5215 rpm and 356lbft @ 4156 rpm with Virtual Dyno
New Dodge Caliber srt4 pistons/rod on the left. Look at the difference on thikness of the rod...
New Spec clutch installed, I replaced later on with a Clutch Masters FX400. The Spec clutch was not able to support 350lb of torque.
you think the auto trans will hold up to that much hp, because i plan on tuning mine but i wanna see if the auto trans will be able to hold that much till i swap to a 5 or 6 speed
