I suppose it is time: andy2964's 03 OZ Turbo Build
Old Aug 5, 2013 | 01:07 PM
  #286
andy2964's Avatar
Originally Posted by Automatic 51
Just when i was thinking i had a handle on this whole project.... Haha.
Read 03lances signature about knowledge and get used to that feeling! I've been in this process of learning for well over 3 years (import/boosted vehicles) and truthfully learn something new almost daily. Its fair to say you are definitely on the right path if you feel lost all a sudden
Look up Merlin's guide to tuning a Evo. I have gotten a great deal of understanding reading this and have read it several times.
Old Aug 5, 2013 | 01:13 PM
  #287
Green_Bandit's Avatar
Oh! I didn't know you had success with it 03. Andy if I were you I'd do a little at a time. I promise you, you don't want to jump into ecuflash with a ton to tweak while learning.
Go with the stock maf first and get the simple things in check then go for the more involved things. Maf scaling is going to be long and a pain while burning a lot of gas. Tuning is not going to take a month, 2, or 3. 03 said two years. This whole time I've been tweaking mine and still have some to go AGAIN due to the change in spool thanks to more preload.
Tuning is the "fun" part of this whole thing.
Old Aug 5, 2013 | 01:22 PM
  #288
andy2964's Avatar
Lol trust me Green I am well aware of this tuning aspect. I've been learning to properly datalog for a little over a year now. For me, that's why I got into this build was to learn the various aspects of tuning. I appreciate the feedback on the sensor. I questioned it at first but decided if I can begin to comprehend tuning a MAF on the stock sensor then if/she. I decide to change over I will have a better understanding.
Just the build a d learning a correct process was a major task in itself and I'm not completely done with this version . I don't think anyone is ever really "done" with their lancers.
Old Aug 5, 2013 | 03:08 PM
  #289
RoadSpike's Avatar
Its this reason that in some regards a SD setup is a lot easier to tune and handle than a MAF setup.
Old Aug 6, 2013 | 09:58 AM
  #290
beautifulpunk's Avatar
I have a gm setup on mine..no issues at all
Old Aug 6, 2013 | 11:52 AM
  #291
03lances's Avatar
Originally Posted by RoadSpike
That is only partially correct. The maf's in these cars are karmen vortex based. They measure airflow based on pressure waves kind of like looking at a flag in the wind and seeing how fast it flaps back and forth as a measure of airflow.
They do this by straightening the air, well sort of straight, with the grid in front then basically put a stick or rod in the middle of it. The air current eddies like water forming pressure waves which it measures either with a pressure sensor or something else which reads the pulses formed. They take the number of pulses and multiply it by the size of the pipe and you get a number you can use for airflow.
As you might imagine any tunneling of airflow say from a S bend in the air stream greatly effects this sensor. This is especially true when you look into one and see the tiny circle like thing that is the sensor. If air swirls a bit or tunnels past it then you can get readings that are too lean, or too rich, and mostly incorrect.
In the evo at least its widely noted that certain intakes and filter shapes greatly effect the numbers you get out of the maf. For the evo at least the HKS filter with its S shape and mushroom filter seemed to cause the maf to experience periods of super high readings followed by lower than normal ones depending of the airflow speed. With advent of air filter mods it was noted that the KN filter with its closed end and open sides provided wildly erratic readings while a filter with open sides and a conical open end piece provided smooth airflow and normal readings.
Nice answer RS . I seen beautifulpunk's question and wasn't sure how to explain it and had not had time to do some more research lol.
Old Aug 6, 2013 | 11:57 AM
  #292
03lances's Avatar
SD is very nice in so much as you dont have to change settings when you change piping . I want to go SD bad just dont have nearly the time to do the proper tuning right now and its my DD. Since I have the maf setup good and i resolved my idling issue awhile back I can be patient.
Old Aug 6, 2013 | 06:22 PM
  #293
andy2964's Avatar
My intake tube is being built for maf setup and have about 3 weeks at most the get it up and running properly, or at least drive able since I know fine tuning will take a much longer. Sound reasonable?
Old Aug 6, 2013 | 06:34 PM
  #294
03lances's Avatar
Absolutely. Within a week I had a reasonable tune on mine quite well enough to just drive for sure and creep a little into boost. After the first month I was boosting happily and wasn't listening for any little noise lol, but it was far from done.
Old Aug 8, 2013 | 03:10 PM
  #295
andy2964's Avatar
Fantastic! I don't intend on manually increasing the boost until I feel a bt more solid in my tuning skills. Choosing a good Evo ROM might be potentially tricky. My thought processes is to use Tephra V7 and have that be the parent with my stock ROM ID as a sibling to allow for a more appropriate tune with the stock maf. Obviously the largest "chunk" of v7 that I want will be fuel and ignition timing and correct maf. Then the abilities look nearly endless with a maf adder, periphery bits, obd tables..ahh chaos! Does this sound like a reasonable start or would flashing a Evo ROM as a parent and copy and pasting appropriate tables to that ROM? I feel like tuning is where the real fun will be had
Old Aug 13, 2013 | 01:00 PM
  #296
andy2964's Avatar
Did anyone ever run into the front o2 sensor being too short? If so what brand did you go with or did you just lengthen the harness? I'm close to a foot too short to make it to the housing...
Old Aug 15, 2013 | 08:31 AM
  #297
2 options. Either find an O2 extender which I looked into but couldn't find the right one or you're going to have to cut, extend, and solder the OEM wires. Do not cut the wires on the sensor side.
Iirc demon said you can actually extend the wires by unraveling the loom a little and not have to cut. If you're feeling froggy give that a shot.
Old Aug 15, 2013 | 09:22 AM
  #298
link62's Avatar
i opened the wire loom a bit and my o2 runs between the turbo and block just fine
Old Aug 15, 2013 | 02:14 PM
  #299
andy2964's Avatar
I was considering this option. If I can refrain from cutting factory harnesses that would be ideal. I didn't want to open it up and come to find it was a waste of time.
Old Aug 16, 2013 | 02:16 PM
  #300
03lances's Avatar
I cut my 02 harness and extended it. Then I ran the wire along the injector harness and down the passenger side. As far as roms go I have tried a few different evo roms and a few tephra roms. Best one I have found to use for us is the 94170715
nj1266
Jan 25, 2026 01:43 AM
evo8lento
76
Aug 24, 2016 11:07 AM
marcouxa1
11
Aug 5, 2016 12:47 PM
Mitsu.kid.02
Lancer Engine Management / Tuning Forums
217
May 25, 2016 10:47 AM
EVO8YEA
Mar 18, 2016 10:44 PM
