Coolant Bleeding?
Old Jun 5, 2013 | 12:55 PM
coollol123's Avatar
Coolant Bleeding?
Hey guys!
Yesterday I changed my upper and lower radiator hoses, coolant, and thermostat.
But this morning I checked it out and both radiator hoses were completely collapsed so I took the radiator cap off and they went back to normal. So there's air in the system. But I don't know where the bleeder screw is for bleeding the coolant system.
Thanks.
Old Jun 5, 2013 | 12:56 PM
coollol123's Avatar
My bad guys! I posted this in the wrong section. My phone is dumb. Admin move it?
Sorry
Old Jun 5, 2013 | 01:46 PM
Green_Bandit's Avatar
Take off the cap, and squeeze the lower hose from top to bottom. Turn the car on with the cap off and let it idle for about 2 minutes and replace the cap and let it warm.
Repeat once it's cool enough.
Edit: oh and fill up your coolant overflow bottle and leave the bottle cap off while you do those procedures.
Old Jun 5, 2013 | 04:24 PM
coollol123's Avatar
Thanks! But, I found out the REAL problem. There is no air in the system. It's the hoses I bought. They are crap. I need to buy different ones, Not from Autozone or Pepboys. Do you know where I can get ones close to the factory ones, or Gator hoses?
I felt the original factory hoses and they are A LOT stronger than the ones I bought from Autozone and Pepboys..
Thanks,
-Coollol123
Old Jun 5, 2013 | 05:33 PM
No air in the system? You're not supposed to. That's why it's pressurized, to hold heat better.
Am I missing something?
Old Jun 5, 2013 | 05:49 PM
AF-Evo8's Avatar
he was saying that there were no air bubbles it was cheap hoses that were collapsing...thin cheap rubber not reinforced
Old Jun 5, 2013 | 05:58 PM
eusgen's Avatar
When I changed my water pump and such all I did was pour fluid back in the radiator til it was full to the top and let er' rip.
Old Jun 5, 2013 | 06:50 PM
tiggeryellow1's Avatar
Veteran: Army
Bro,
If you're talking local shop you should do better at NAPA. If you are talking online I would go summit racing or lancershop.
03whitegsr
47
May 29, 2018 11:11 PM
DFelton
Aug 8, 2012 08:00 AM
mdsevo06
24
Apr 14, 2011 03:45 PM
OMEGA BLACK 79
20
Dec 18, 2009 07:54 PM
MitsuJDM
10
Oct 22, 2008 06:57 PM
