Upper oil pan STUCK!
Old Jul 12, 2013 | 10:43 PM
=AA=ExisT[TFCC]'s Avatar
Took the lower one off, took all the bolts out. Tried beating on it, swinging from it, and prying it off with a screwdriver. No luck. Mostly I think because I can't get anything in the gap far enough to get leverage.
Ideas?
Old Jul 12, 2013 | 11:27 PM
Btw I had to pry the lower oil pan off too. Beating on it did nothing. The car only has 71000 on it... I don't know if someone used too much gray goop or what...
Old Jul 12, 2013 | 11:37 PM
Green_Bandit's Avatar
Positive you got all the bolts out of the upper? There is a notch between the pan & the transmission use your pry bar there. Don't do it between the block and pan. It's definitely gooped in there. Just keep trying that notch.
Old Jul 13, 2013 | 08:04 AM
marcouxa1's Avatar
You definatly forgot 1 bolt....i had the same problem untill i found 1 bolt that i forgot and then it comes out with only little pry!
Old Jul 13, 2013 | 08:10 AM
Ok thanks, I'll do that. And if I still have problems I'll post pictures to make sure I got everything. :-)
Old Jul 13, 2013 | 08:14 AM
Hrmmm, I can't imagine where, unless there's one that goes through the block or something first and THEN into the pan?
Is the place where the oil filter attaches actually connected to the pan? I found a mitsu diagram with the pan and the oil filter doesn't appear to be connected...
I might have better luck in daylight today.
Old Jul 13, 2013 | 10:35 AM
I'm going to have to take the damn downpipe off aren't I?
Grrrr
Old Jul 13, 2013 | 11:13 AM
Got it. What a pita. Thanks for the help evom!
Old Jul 13, 2013 | 12:38 PM
Got the hole drilled, also a pita (didn't have the right drill bit.)
10an fitting to be welded on monday by my brother at his work.
Something tells me I am not ready to be attempting to install a turbo. But I'm doing it anyways. Only one way to learn, do!
Old Jul 13, 2013 | 03:37 PM
eusgen's Avatar
I am right there with you bro keep it up
Old Jul 15, 2013 | 04:58 PM
How is your build going eusgen?
Welded!
[img]
http://s43.photobucket.com/user/bdho...age-2.jpg.html
[/IMG]
Ps how do I post images? Lol
Old Jul 15, 2013 | 05:09 PM
Photobucket is completely impossible to use with an iPhone :-/
Old Jul 15, 2013 | 09:05 PM
I kinda wish someone had told me that taking the oil pickup off makes things about a zillion times easier while tryin to put the pans back on lol
Old Jul 15, 2013 | 09:12 PM
It's aggravating to do put I've never taken off the pick up.
Dapper Dan
16
Feb 26, 2017 08:00 AM
CopartJohn
E85 / Ethanol
Aug 11, 2016 10:25 AM
Jsiebert
Aug 11, 2015 01:23 PM
manthny18
Jul 3, 2015 05:33 PM
SikEvo8
14
Feb 13, 2013 03:25 PM
