Help me with my turbo install thx k bye (2002 OZ Rally)
#31
I don't know much about oil. So I did research on here about what oil to use and narrowed it down to 20w 50. I have 175,000 miles on this motor. When this motor craps out I will be swaping in the same 4g94 engine with 50,000 miles on it. Should I use the same oil then?
Got this car in 2013 not knowing how to drive manual or change my oil. Never owned a Turbo'd car before...
When I start running boost usually my eyes get big and adrenaline kicks in. Then I push the clutch, hear the bov, and I scream some sounds (of excitement) ....not words but sounds
20w50 is way too thick/heavy for your engine...I would go to 10w30.
research oil viscosity vs. temperature...when your engine is turbo charged, the oil will be hotter than normal if you're not using an oil cooler, as it passes through the center section of the turbo, which gets hot as ****...
#32
https://www.evolutionm.net/forums/la...c-oil-bad.html
https://www.evolutionm.net/forums/la...bo-lancer.html
10w30 mobile 1 is what i ran NA. The posts above are the reasons i switched to 20w50.
#33
Started data logging knock counts today. Some peaked at 18. I have been working on it and its starting to make sense. Got all of them down to at least single digits. Just came back from a drive and logged a high of 3. Feels good to make progress.
#34
there are some really great DIY tuning threads on here, specifically in the Evo 1-9 section.
#35
you have an oil pressure gauge what type of pressures you running at idle. I agree that 20w-50 is excessive for this engine it does have a bit of miles on it. so perhaps it needs the thicker oil to have enough oil pressure. though if your turbo is in good working order it may not like that. also I have and will always run synthetic oil in my lancer with or without boost, I use to run Mobil 1 and have had no issue though I am going to be switching to AMS oil here shortly. good luck on the tuning it always feels better to have done something yourself. keep up posted ever plan on getting it dyno'd to see what its putting down?
#36
There's absolutly no rason to run 20w50 engine oil in your car man....i race my car on on the track and im using 10w30 oil! Make sure ur using synthetic oil because conventional oil breaks down at lower temperatures and leaves deposits in the turbo oil passages which leads to no lubrification on the turbine shaft journal bearings and then shaft play comes in and destroys your housings. Im using Amsoil Dominator 10w30 oil and i havent had any problems running it on the race track in the past 2 years.
#37
Just went to MAPerformance Subie car show. They had 60 dollar dynos available. Since im not done tuning i didnt sign up. But the show was good. It was there first year but nice turn out. Mitsu car show is next Sunday which will be much better.
Had a prosport wideband which i found out is hard to log with... So i got an aem one. Now i can log my afr! Yay!
maperformance (Aug 23, 2016)
#38
Little update:
Changed the oil a couple weeks ago and its been running great so far. So far I like the no power steering. Parking lots are not bad. Its hard to steer but haven't had any problems. Wet roads make it really easy to steer also. When the car is moving I can use two fingers to hold the wheel.
Made a clip of me heading on to the interstate. Its almost a perfectly flat road. Very small incline. Check Engine Light never flashed... always a good feeling.
