FMIC Gains?
Old Apr 7, 2004 | 02:00 PM
pgmike's Avatar
FMIC Gains?
I have the rrm nonIC turbo kit right now, but want to get a FMIC. If i get it ill be able to boost one or two more lbs, but will i also be getting more hp per lb?
Old Apr 7, 2004 | 02:11 PM
Guru_Del's Avatar
yes you will gain more HP per lb.
I noticed a large increase on my car.
Old Apr 7, 2004 | 02:12 PM
IILANCERII02's Avatar
yes, you will see some more hp/tq per psi you add when you upgrade to the FMIC. Guru_Del upgraded and i believe is at like 13hp per psi or something crazy like that.
Old Apr 7, 2004 | 02:13 PM
uppp responded .2 seconds before me there vince
Old Apr 7, 2004 | 02:15 PM
pgmike's Avatar
so if i turn up the boost to 8 that will be 8x13=104whp sounds a little high to me. that makes it 102stock+104=206. Boe has stage 2 and lots of other stuff and is only getting 233whp.
Old Apr 7, 2004 | 02:17 PM
im not sure, but i think vince has like just under or right at 200, i cant find his thread that he made with the dyno or his car with the IC
Old Apr 7, 2004 | 02:20 PM
psionic98's Avatar
8*13=104 yes, whp = no... thats 104hp in general, probably to crank.. only expect to see about 80-90 to the wheels
Old Apr 7, 2004 | 02:25 PM
pgmike's Avatar
vince dynoed his at 193whp at 6.8psi i think so that comes out to over 13whp/psi. vince do you know how many whp you wre getting per lb b4 the IC?
Old Apr 7, 2004 | 02:44 PM
Im pretty sure - not that im speaking for vince - but i saw that ROCK made a post just recently that said like the non-IC kit ran like 170 or 180whp i believe, dont quote me, but im pretty sure thats what i read.
Old Apr 7, 2004 | 09:22 PM
HobieKopek's Avatar
See NTran999's dyno sheet.
daechul2da
Oct 31, 2011 12:56 AM
dragon831
28
Feb 3, 2009 04:08 AM
Jeeperjunior
Feb 29, 2008 05:43 PM
t51quicksilver
Nov 19, 2006 11:09 PM
titaniumkingpin
11
Aug 27, 2004 06:49 PM
