Wiring problems
Old Dec 7, 2002 | 03:46 AM
Redlite's Avatar
Wiring problems
Okay guys, this is a question for all you installation wizards. I installed an HU, amp and subs last night and have run into 2 problems. First is that except from my subs I get no sound unless I toggle the running lights off or on. I'm sure this has something to do with the front ECU (taillight relay) wire but I have no idea where to connect it to my deck. Second is, I've checked all my connections but I'm not getting any sound from my rear left speaker. Any help would be greatly appreciated.
Old Dec 7, 2002 | 07:44 AM
ryancb's Avatar
did you use a harness, did you check with the wiring diagram here also did you ground right?
Old Dec 7, 2002 | 12:18 PM
Redlite's Avatar
used the harness from the HU, but there were 3 wires (coming out of my dash) that I had no idea where to put them. And yeah everything is grounded.
Old Dec 8, 2002 | 11:43 AM
Redlite's Avatar
Come on guys, I know I'm not the only one to install my system by myself.
Old Jan 10, 2003 | 12:32 AM
LBLancerDude's Avatar
yeah on my head unit i dunno where to put my ground... theres no ground for the wiring harness i bought... what did all of you do?
Old Jan 10, 2003 | 12:34 AM
ryancb's Avatar
i ran a wire 2 back seat area for my neons and leds and grounded hu 2 frame of car just losten a bolt and stick wire in it or run a ground 2 somewhere like seatbelts
Old Jan 10, 2003 | 12:44 AM
1DVSOZ's Avatar
the ant wire is a ground onec you plug it into your stero it is grounded if you got a aftermarket harness the digram it came with will let you conect it to your head unit then you simply plug it into the harness that came off the stock unit. circit city sells the harness for about $20. hope i was able to help
Old Jan 10, 2003 | 09:58 PM
Redlite's Avatar
thanks
Old Jan 10, 2003 | 11:45 PM
crusin_lancer's Avatar
I grounded my HU to the bolts behind the HU. Just added an extra nut and stuck the ground between. If your left speaker ain't working check the diagram make sure your wires are crimped correctly and aren't loose. Remember the black or white stripe is negative.
crabs_mcjones
May 29, 2016 11:41 AM
MidMex
Feb 24, 2010 04:15 PM
_03ozRally_
10
Mar 7, 2009 07:13 PM
c900t16
Nov 21, 2007 10:08 AM
V8EaterEvo
Jan 22, 2006 08:12 AM
