Evo Rs with lost aux pwr!
Old Feb 27, 2005 | 07:21 PM
spyderx's Avatar
Help guys,
I must have shorted somewhere and now I have no ignition on or aux pwr.
I ve checked all fuses and non are blown. So I'm lost.
Can someone direct me???
thanks!
Old Feb 28, 2005 | 02:57 AM
OZLancerlunatic's Avatar
You checked all fuses under the dash AND in the engine bay? if you have and none are blown then somewhere that wire is cut.....find the wire and follow it.
Old Feb 28, 2005 | 03:04 AM
mrbkkt1's Avatar
what were you doing when you lost power? that might help us narrow it down.
Old Feb 28, 2005 | 08:43 AM
spyderx's Avatar
I was rigging or hardwiring cigarette light 12v plug to aux in wire so I don't have to occupy a cigarette lighter when pwring my Delphi XM receiver. I must have shorted then.
I've checked all fuses except a pair under the hood. In evo, there's a pair of fuses embedded within yellow plastic plug and its PITA to take out. I did'nt know you could take them out. But apparently one of them is for radio pwr.
I'll have to check those out...thanks guys!
Old Feb 28, 2005 | 08:58 AM
Iamkar33m's Avatar
That yellow plastic plug IS removable and one of the fuses inside them is your problem. I know that because when I left my car on campus overnight cuz i couldnt drive home I pulled those fuses because that way it's impossible to get the car started without replacing them
Old Feb 28, 2005 | 10:40 AM
spyderx's Avatar
hmmm, you can pop them out half way but I could'nt remove them all the way.
how did you take it out?
Old Feb 28, 2005 | 10:56 AM
Iamkar33m's Avatar
When u pull it out 1/2 way there are 2 tab-like things that u should be able to see on the sides. Squeeze them in and pull the yellow thing out the rest of the way.
Old Feb 28, 2005 | 11:06 AM
spyderx's Avatar
thanks dude!
Old Feb 28, 2005 | 11:21 AM
DaWorstPlaya's Avatar
I don't know if you took off your center arm-rest and shift cover to get to the cig lighter but if you did, there are 2 plugs on the side of the handbrake, make sure those are properly plugged in or your car won't start.
bm12321
Dec 22, 2016 09:32 AM
Dstorm7
Lancer Troubleshooting
Feb 6, 2016 09:24 PM
spyderx
Jun 18, 2012 06:45 PM
EvoVIII808
Jun 20, 2009 07:53 PM
xtnct
Sep 12, 2003 06:17 PM
