Engine Noise
Old Mar 19, 2003 | 01:07 PM
Thwack's Avatar
go to radio shack, buy a ground loop isolator for like 5 bucks, wire all your audio system grounds to it.. if you ever get a video screen, hook that ground into it too.. nothing worse than getting ground loop interference in a screen... you het horizontal lines running across the screen whenever you rev.
Old Mar 19, 2003 | 01:11 PM
cupOZnj's Avatar
Originally posted by TurboZ
ground the radio. and of course the subs would not make a high pitched noise... the frequency respnonce on subs is usually below 2KHz. try another ground or put a filter on the antena
if your subs are putting out 2kHz than you are doing something wrong. my subwoofer puts out nothing above 100Hz. you should leave the 200Hz and above range for mid-bass. the 2kHz range is still in the voice range.
Old Mar 19, 2003 | 01:16 PM
cupOZnj's Avatar
i have my headunit grounded behind the dash to a bolt, the ground wire is about 8" or so. my amp is grounded to a bolt in the trunk for the gas tank, the length on that is about 2 feet. optimally you should not have grounds more than 18", but definitely not longer than 5 feet. all the amps should be grounded at the same place. since the stock headunit doesn't have a ground wire, just make sure the area you ground it to is very clean.
also make sure you run your power cables on one side of the car and the RCA cables on the other side. that is important too.
Allentotora
May 24, 2017 07:59 AM
Wallesasuaz
Jul 24, 2008 09:39 AM
Addicted4Life
Northwest Region
Jan 28, 2008 10:49 PM
that_2g_guy
12
Aug 16, 2003 08:51 AM
blaze_125
22
Jul 13, 2003 08:13 AM
